Old 07-18-2007, 09:43 AM
Kurt S Kurt S is offline
Default Re: "Engine" Temperature Measurement.
I believe the standard place for measuring coolant temps with the IR gun is the thermostat housing.
For calibrating your gauge, just pull the sender unit out and put it in water. Measure the water temp with a thermometer. Compare.
Repeat with hotter water......
Kurt S - CRG
Old 07-18-2007, 10:42 AM
mockingbird812's Avatar
I had heard that was most folk's practice - using the thermostat housing. But from what I understand that Mark said, shiny or light colored objects do not give a true reading. My housing is unpainted aluminum.
Sam...
Old 07-19-2007, 07:26 AM
Dusk Blue Z Dusk Blue Z is offline
Sam,
The reading you would get from the upper radiator hose would be an accurate temperature of the surface of the hose not the fluid inside it. I am at a customers site this week and don’t have access to all my reference material which would list the different emissivities for materials and paint colors. The emissivity number is a multiplier for the radiated heat that the radiometer picked up to give an accurate temperature reading. Your unit is fixed at 0.95, the more expensive units would allow you to input the number for your target material.
I think if you read off the top of your bare aluminum housing you would be within 5 degrees of the true temperature.
I am making plans to attend SCR 10. If anyone would like to have me measure their car to check their gauge accuracy just drop me your name and description of your car and I’ll look you up.
Mike
Old 07-19-2007, 10:12 PM
Mike,
Thanks again for your insight. This has been very helpful to me. I have spent a good part of my career in sensors, just in a different part of the spectrum. I can always learn something new.
Good gouge:
<font color="blue"> [ QUOTE ]
</font>
Sam...
