Old 06-27-2007, 07:27 PM
Default Re: Turbo Blue Racing Fuels
Identical results in a 4:10/TH400/11:1 396,running TBlue too.
Old 06-27-2007, 07:59 PM
Open headers takes care of the problem!!! Restricted pipes & mufflers will raise the temp.
Jake is my grandson!!
Old 06-27-2007, 08:33 PM
k92 k92 is offline
Last week turbo blue was $3.99 a gallon here.
Old 06-28-2007, 02:31 AM
SSJunkie68-69 SSJunkie68-69 is offline
Actually located a place that sells it about 60 miles from me. Going up in the next couple of days to pick some up. From what I understand as long as you run up to a 25% blend there would be no need for a jetting change for the 115 octane leaded brand they sell. Anything beyond that will require a change.
Old 06-29-2007, 12:20 AM
lzdick lzdick is offline
Here is a website for race gas in Illinois. http://www.local.com/results.aspx?keywor...CFQldQAodCT7U1A
Not sure if there are websites for each state. I just typed in 'race gas' on Google. This link was on the right entitled 'race fuel'.
Rich
L.Z.
"...at this point in my life, every day is a Saturday".
Old 07-02-2007, 07:33 PM
Went up with one of my daughters and picked up some Turbo Blue on Saturday morning. Nice drive through some mountains to get to the Fuel and Feed that carries it. Put it in the cars at a 25% blend and the results were impressive. This is GOOD STUFF. If you have a big block engine, give this a try. It costs me $5.29 a gallon but for an extra $10.00 a tank it's well worth it. It makes so . The L34's responded very nicely with it but the L89 really got off with it. One of my other daughters even said she loved the smell from the exhaust once the engine was running. I do believe I am hooked on this stuff now.
Here's a link to the site : http://www.turboblue.com/ . It will direct you to the closest selling dealer to you.
Enjoy~
<span style="font-weight: bold">I've been in my mind, it's such a fine line.....</span>
Old 07-03-2007, 06:51 AM
Belair62 Belair62 is offline
I think on a stock 427,LS6 or LT1 you are wasting money running straight 115 octane. Mix is probably very sufficient.
Old 07-03-2007, 07:05 AM
427king 427king is offline
Yenko Paid Member
Here is a dyno sheet on my L89 that was run last week. Straight 93 octane. Pretty good results for a stocker 396.
Old 07-03-2007, 10:45 AM
markjohnson's Avatar
Race gas is like Viagra. Unless you really need it, it's not going to help you. Most people when they rebuild these old engines use a Fel-Pro Permatorque head gasket thats twice as thick as the old steel shim head gaskets and that does to tend to knock(pun intended) some compression out of these motors. You wanna put pump gas in your L72. Just put on a set of aluminum heads and Fel-Pro Permatorques and watch how that thick head gasket and aluminum's thermal effiency tames that beast down. Great way to neuter a Rat.
Old 07-03-2007, 07:04 PM
Chevy454 Chevy454 is offline
I put together an L72 a few years back just as the factory would have, just to see how it would stack up...I had to remove just the slightest material from the deck/heads to clean 'em up, and when I cc'd it, it still came in at only 10.2:1 compression. I've heard of a similar rebuild on a Berger L72 that came in at 9.8:1 compression. Anyway, I ran a mix of premium and race gas, until the car was really sluggish at the track one night...I went with straight Premium after that and never had a problem. Thing went 12.7s @ 108+ in our heavy car, and coulda went quicker had I knew then what I know now.
Now, our current 12:1 L72 is a different story...
