Old 05-18-2007, 02:45 PM
68Biscayne427 68Biscayne427 is offline
Default 68 Biscayne Motor Mounts
Looking for a pair of original motor mounts for my 68 Biscayne Big Block. They don't need to be NOS. I would like to stay away from after-market if at all possible.
Thanks - Rob
Rob M.
'68 L-72 Biscayne, M22 4-speed
Old 05-18-2007, 06:13 PM
Default Re: 68 Biscayne Motor Mounts
Can one of the moderators remove this and put it in the correct category? (Parts Wanted) - it is in the wrong category. Sorry for the mistake.
Rob M.
Rob M.
Old 05-18-2007, 06:26 PM
Casey Marks Casey Marks is offline
Do you need the steel perches that mount to the frame, or the rubbers ? If you need the perches, I've got a set that I'd sell.
Casey
Old 05-18-2007, 06:39 PM
Hey Casey,
I need the rubbers. There are a couple on ebay right now but I don't need NOS. I may have to spring for them if I can't find any nice used ones. The problem I am having is the wrong mounts are installed and my motor sits too low. My cooling fan hits the bottom of the fan shroud and the oil pan is so close to the tie rods that it is rubbing! You would think the "person" who installed this motor would have used the correct parts!!
Thanks for the offer Casey - Rob M.
Rob M.
Old 05-18-2007, 06:55 PM
jasonL78 jasonL78 is offline
I have a complete 68 396 out of a fullsize car. I will have to look at the motor to see if they are thier. I bought a set for my 68 bb nova from gm 2 years ago, they are still offered. If you know the part number I would make a call to your local gm dealer to see if you can still get them. I will check the motor and get back to you.
Old 05-18-2007, 07:43 PM
Thanks, Jason
Rob M.
Old 05-18-2007, 08:37 PM
Tarrytown SS427s Tarrytown SS427s is offline
Jason, could you post all the numbers stamped on the front pad of that 396? I would like to add it to my database.
Steve
Steve
68 Caprice Estate
68 Camaro SS396 4 speed
Old 05-19-2007, 01:58 AM
well not sure if these motor mounts are what you are looking for but the motor is out of a 68 fullsize car and it is complete from air cleaner to oil pan. I got it with my 67 chevelle but I am going to use another motor for the project. I plan on using all the hardware for my 68 bb nova L78 motor. The motor block is dated may of 68 and it is a 2 bolt 440 block. I may sell some parts off it if anyone needs them send me a pm. But I have some parts like I said reserved for my motor.
