Old 04-07-2007, 09:32 AM
70Z28RS5151 70Z28RS5151 is offline
Default 1970 Z28 Project
I am selling my project 1970 Z28. It is a real (documented with build sheet) 1970 Z28 RS 4 speed car with deluxe interior built (06D) in Van Nuys CA. There may be another build sheet in the headliner... the headliner is original and intact. It was sold from F.H. Daily Chevrolet in San Leandro, CA. All options are legible on the build sheet that I found on the gas tank. This is a true factory 4 speed car as well as true factory RS car. This car does not have it's original born with engine block and transmission. A Muncie will be included… it is an M21 or M20. A (E 18 0) dated 3970010 4 bolt 350 block (#2482 casting main caps) and a set of 186 casting camel hump heads dated (E 17 0 and E 19 0) will be included with car. The engine block and heads will require machining. This Z28 has a 4.10 (C O O) 12 bolt and is called out on the build sheet. Original 5 spoke steel Z28 wheels with 1" X 13/16" oval valve stem holes with Firestone Wide Ovals are included. The interior of the Camaro is black deluxe with console. The deluxe door panels are in excellent condition and the best I have ever seen. The deluxe RS wheel is crack free. The center console with 4 speed deluxe bezel is also very nice. The deluxe front buckets and rear seat have original covers, the drivers side has a small tear. Original dash is curled, but not cracked. The complete interior except headliner and dash pad are out of the car now. The car is a roller. The body has very little rust. The rust that I can see is at the base of the pillars behind the windshield on the dash panel and on the trunk floor well. The passenger fender has rust but I have a correct original fender that is included with the car. The floorboards and framerails are rust free. The quarter panels are original and rust free. The original RS nose still has a nice fit. The original color is 51 51, Daytona Yellow with black stripes. The body is covered with dark gray primer now. The car will require a complete body and paint restoration. I believe an original Daytona Yellow, factory 1970 Camaro Z28 Rally Sport 4 speed with black deluxe interior is very rare. I really haven't begun yet to strip the car to the shell to have it media blasted to the metal. It was my plan to start this part of the restoration. Aside from the build sheet to prove it's authenticity is the fact that the gas pedal is mounted to the floor board, the gauge cluster has a 150 speedo and 8 k tachometer, the u-shaped sway bar brackets are factory welded to the rear frame rails, the rear bumper has 2 bumperettes. The price is $14500 for my project. Original engine or not... these cars are going up in value every year. This is a very rare color and interior combo. Come and get it before I change my mind again.
Please call or email if you have questions.
Car and parts are in storage, I will try to post pics ASAP.
Tony 510-299-2747
Attachments - The Supercar Registry 263922-Daytonabs002(Small).jpg 263897-Daytona005(Small).jpg 263797-tn_Daytona014.jpg 263793-tn_Daytona002.jpg
