Old 03-15-2007, 05:58 AM
kwhizz kwhizz is offline
Default Don't you just hate when that happens
For the last couple of day's I have been changeing the Engine and transmission in the 66 Chevelle Convert.....everything went smooth with the Engine,....I swapped out the powerglide for a 700R4.......pretty basic swap......ordered a Shiftworks conversion kit and installed everything inside the car and the only thing left to do was to hook up the shifter cable to the transmission shift arm......Fill it with fluid and start for the first time....got the car on the Lift and mounted the Cable Bracket to the trans......Simple......just hook the cable to the arm and "Done".........Put a wrench on the Detent Arm on the trans to install the new arm..........
Darn.......................
Ken
