Old 02-02-2007, 04:38 AM
JChlupsa JChlupsa is offline
Default Re: 63 Galaxy 427, 2x4
VIN tag shows 3J66R for a 63 Galaxie 500 427/8v car. Org drivetrain is all there but half the car is not-->(Rusted away ) To bad they let it get so rusted out. Complete donor car would have to be found for the operation and I do mean operation.
Old 02-02-2007, 04:40 AM
bkhpah bkhpah is offline
My 427 Hi-Riser car had a sound like no other car I have ever been around. A total beast. I love those FE Fords..BKH
Old 02-02-2007, 04:54 AM
Old 02-02-2007, 05:01 AM
Yikes!
That's too bad
Old 02-02-2007, 05:34 AM
PeteLeathersac's Avatar
Thats quite the patina...but I think I like it!?.
Don't touch the body...just get it running and drive it as is!.
~ Pete
Old 02-02-2007, 06:56 AM
tom406 tom406 is offline
Sigh. From what I can see on the tag, it was origially Champagne(code I) with a Red interior (code 95) delivered to Los Angeles sales district (DSO 71) running a 4 speed (code 5) feeding a 4.11 open rearend (code 9, posi-type diffs were letters). Somewhere in California there's a donor waiting to make this happen. Motor should be checked to make sure its still the 427 and if its seized, you've only got a .020 or .030 overbore possibility, and that's if there's no excessive core shift. Otherwise its sleeves. The main VIN is on the upper left corner of the firewall, right where all those leaves and crap are sitting. I'd make sure that was still intact before proceeding as well. No small task, but its definately more than tags and a title, right?
Old 02-02-2007, 08:20 AM
any idea on how many were made?
Old 02-02-2007, 09:12 AM
I remember looking at one of these back in 1986 at a place called the Toy Store here in Houston. The owner had just picked it up in Nashville TN and it was in pristine condition. Brown with tan interior, factory tach on the dash, 427, 4 speed, those dual 4 barrels, tubular looking exhaust manifolds, and the sound of those solid lifters. Very nice car but I wasn't into big Fords at the time.
The salesman wanted $6000 for the beast.
I wish I could turn back the clock.
Paul
Old 02-02-2007, 09:13 AM
Just under 5000 (4973 is one figure I've seen) 427 equipped full size Fords were apparently made in 1963. These Galaxie 500 Sportsroof (aka fastback) models were probably the most popular. Custom 300, Galaxie, Galaxie 500 and Galaxie 500XL were the trim levels.
Old 02-02-2007, 11:04 AM
sixbrl440 sixbrl440 is offline
Oh, man, the Ford love is flowin'
5th digit of the VIN is what you're looking for.
427 8V = R
427 4V = Q
406 6V = G
406 4v = B
390 4v = Z
Do the engine block check, casting numbers will be on the side (C3AE -M or AB) and the bolt heads just above the pan rail on the sides will be there on a 427. Cylinder heads will have casting numbers in the spaces between the exhaust ports- early cars will be C3AE 6090-D (Dec '62-Mar 15 '63) and later ones will be C3AE 6090 G or H (Mar 15 onward). This is key for value because almost every early 427 or 406 Galaxie that was pressed into duty as a regular car got fitted with a 390 later in life (mine had a '65 Mercury 390 2V in it). Assembling a correct 427 will end up costing you $6 to 10K. Look to see if it still has the long cast iron headers as they run $600-$1000 per pair. Trans will be a BW T10, but '64 Galaxie Toploaders are a common substitute. Car should have 3" front brakes, no power steering or brakes, and should show evidence of always being a stick car. VIN is on the firewall tab, trim tag, and there's a hidden one under the back seat, either on the front edge of the package tray or down toward the floor. Let me know if you need any more info...
TOM BRESKE
427 425 on stand:
427 425 Bottom end:
Still ISO the thieves...RIP, Larry Clain
