Old 01-03-2007, 08:36 PM
dlv4540 dlv4540 is offline
Default 1965 396-425HP corvette Z16 engine
This is an original 1965 396 4bolt block casting number 3855962 with a date code of E-23-5 and front pad of T0712IF with vin number still intact. This is authentic and I guarantee this not to be a restamped block. The block has been cleaned, magged and pressure tested and will remain standard bore and ready to drop the original pistons back in it that I have as well as the original rods. I have the steel 6223 crank already installed back in the engine and it is standard as well. The motor will come with the original square port heads casting number 3856208 dated E-22-5 and the original intake casting number 3866963 dated 5-18-65 as well as the original waterpump casting number 3856284 dated F-16-5. I have the original high volume oil pump as well for the motor. The heads have been cleaned up and pressure tested after minor repairs and will need resurfaced, valve job and guides installed. These parts are in great overall condition and the block is as virgin as you will ever find. $12,500 for this set up and serious inquires only by phone 330-638-0511 or 330-770-2517 after 11am. I have access to the original exhaust manifolds dated F-7-5 and the original distributor as well.
Dennis Vugrinovich
