Old 12-29-2006, 07:18 PM
Default Re: 350 LT1 compression...Lower it?
Jim, when you say the 'stockers were .020 compressed' were you referring to the steel shim gaskets? I reinstalled the steel shim gaskets on mine, I think they were .018'ish ??
I think Keith is right, these cams bleed off a lot of the cylinder pressure so pinging is not too big of a problem - especially if you turn the timing back a little. I found that running 93 and turning the timing back a bit significantly altered the 'seat of the pants' performance, but... could've been in my head
Old 12-29-2006, 08:24 PM
Donnie's Avatar
Donnie Donnie is offline
Tony,
my .30 over 11:1 LT1 ran just fine on 93
69 SS L78 Chevelle
70 SS 396 Chevelle
Old 12-29-2006, 08:31 PM
Chevy454 Chevy454 is offline
Granted this pertains to BBC's, but going from memory the AMA specs list the head gasket [steel shim] at .018"-.020"...
Old 12-29-2006, 08:34 PM
BUIZILLA BUIZILLA is offline
I don't think they ever got to .018 unless it was an early editions...
indexing plugs??? uhhhh, hell yeah, usually takes me 20 to get 8 to line up right, so I buy 50 at a time to get maybe 3 sets..
crackle ??? yeah, it's got a tad of a pop to it at 7400 it doesn't crackle, but dammmmmmmm does it sound good....there is no better music than an x pipe exhaust and a small block at 7400...
aka - Mighty Mouse
Old 12-29-2006, 08:38 PM
bilede bilede is offline
Hell no, I don't quite understand why everyone lowers the compression and yet is so worried about the car being 100% original, numbers matching, as rolled off the assembly line. we like them because they were hi compression, great sounding, running, and a little crazy at times.. don't lower it is my vote!
Old 12-30-2006, 12:32 AM
TDW TDW is offline
Thanks everyone. I will not have them cut. I ordered the cam from Crane. Should be good to go now.
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
