Old 12-28-2006, 04:29 AM
TDW TDW is offline
Default Re: Looking for driveshaft
You may have better luck with a wanted ad at www.chevelles.net. If I run across one, I will foward the info to you.
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
Old 12-28-2006, 09:11 AM
Musclecarkid Musclecarkid is offline
The 454 driveshafts are very hard to find anywhere. A good driveshaft shop can make one for you by changing the welded yokes and shortening a typical Chevelle driveshaft to about 54-1/2 inches. Rememeber the 454 cars used wider u-joint and no outside clips. I believe the u-joint and weld yokes are 3R style. Pontiac used these yokes on many cars. Parts are easily obtainable from your local driveshaft guy. Look under your bro's other LS6 car for exact measurments. Also I believe the difference between Auto and Stick is only around 3/4 of an inch. Both used the large TH400 slip yoke at the front and the rear flange on your 12 bolt must also be the wider type. Good luck.
Kevin
1970 Chevelle Droptop
Period Correct Speed Parts
482 BBC, M22 or TH400?
Day 2 Super Stock Rocks
Old 12-28-2006, 05:56 PM
MosportGreen66's Avatar
If finding an original unit is not happening, having an original-like unit created seems like the next best thing to me.
The Drive Shaft Shop
210 Blydenburg Rd
Hauppauge, NY , 11749
Phone: 631-348-1818
FAX: 631-348-1844
Toll Free Phone: 800-564-2244
Old 12-29-2006, 06:09 AM
Mr Yenko Mr Yenko is offline
Thanks guys for all you advice.
The "MOF"
"POTTER BROS. SUPERCARS"
72 Nova SS "My first car of 30yrs"
70 LS-6 Chevelle Double Blk 30k survivor
