Old 12-13-2006, 08:26 AM
427freak 427freak is offline
Default Re: 68 Yenko Camaro rally wheel size.
Hello James
I have a JA because that is what I had heard was the correct wheel. It does clear the orig caliper upfront. Anyone have another JA? Thanks
Dana
MBTMF
Old 12-13-2006, 09:12 AM
firstgenaddict's Avatar
Dana,
Check the Pontiac Boards under Firebird Parts and GTO Parts if nothing there post a wanted ad the JA's are on there quite frequently. Performance Years Forums
Also there could be 2 different JA stamps. There are 2 different JC stamps the 67-68 one uses a larger type font and the dates are inside the tire on the center bands. Then the 69 up which has a smaller JC stamp and the dates around the valve stem. I believe that the JA's follow the same pattern.
Good Luck... if you run into a couple of big letter JC's I could use them...
James
~JAG~
NCRS#65120
NUMEROUS Lemans blue Camaros,
& a Chevelle or two...
