Old 10-22-2006, 09:16 PM
scuncio's Avatar
scuncio scuncio is offline
Default Ahhh crap....
So I was mentally committed to selling my '68 Z (cool old drag car with 25k original miles) and went out to the garage to take it out to shoot a few pics. And I find this puddle of 80W on the ground! Looks like I am keeping it for a while. Anyone had experience in fixing a cracked weld on the spring perch?
Old 10-22-2006, 09:40 PM
Default Re: Ahhh crap....
Tony,
Whay would a cracked weld on the spring perch have any bearing
on oil leakage? Why would the two be connected? Is the
axle seal bad possibly?
Steve
Old 10-22-2006, 09:41 PM
enio45 enio45 is offline
I dont, but i would love to see a pic of the car . . does it have good documentation with it?
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 10-22-2006, 09:59 PM
scuncio's Avatar
Steve, the crack appears to have gone through the tube, so whatever lube was residual has now trickled through the crack onto my garage floor. I've seen this before on cars that were beaten pretty hard...I guess mine qualifies.
Ed, I'll take a good pic of the car as soon as I get this stupid thing fixed!
Old 10-22-2006, 10:20 PM
markjohnson's Avatar
That was a common problem on Camaro/Nova leaf spring perches. I see you have U-bolts instead of the T-bolts. That normally takes care of spring perches breaking away from the tube but obviously not in this case. The best known solution is to keep the U-bolts and weld small gussets from the front and rear of the perch up to the axle tubes. That, or stop with the power shifting and we all know how difficult that habit is to break! By the way, axle tubes retain plenty of gear lube. That's why 12 bolt differental covers have that ridge on the back side, so lubricant flows down from it to make it's way down the axle tube to the outer rear wheel bearings. Good luck.
Old 10-22-2006, 10:33 PM
bertfam bertfam is offline
Tony,
This is your cars way of telling you not to sell it!! She's happy in your garage and doesn't want to leave.
Ed
Ed Bertrand
1968 RS/SS L-89
396/375 Convertible
CRG Member
Old 10-22-2006, 10:38 PM
Tony,
Ed
Aaah yes, tears of sadness......
