#11
#12
engine
#13
tag
#14
Interior
#15
You should ask the previous owner if he as the original parts for the car. I.E. Air cleaner, valve covers, intake, carb, exhaust manifolds with smog setup, etc. Also the car should have the small rear bumper guards. He might have the stuff laying around.
Good project. Rick H. |
#16
Question I thought z28 cars were referenced on the trim tag mine has Z28 on the trim tag. I see the emblems on the car but not on the tag... |
#17
Here is mine...
#18
Some cars did not have the "Z" in front of the 28. I believe you will find the code either way up to around the middle of April, 1970. Somewheres around there.
His tag is correct for his car. Rick H. |
#19
Hello, the trans is a 661 case with a P code of B so its a M21 and the vin is on the side of the case that matches the dash. The starter is a 418 and dated to the car. The heads are correct 186 and dated also to the cars build date. Thanks, Larry.
#20
Hello, I have another done Z that is a July car that has the full Z/28.10 on the tag. I'm sure this other one is a Z also. Thanks, Larry
