Old 07-05-2006, 03:27 PM
ohhawk ohhawk is offline
Default Re: LS5 Ragtop on Ebay
Very nice car. Would agree with some that the buildsheet needs further scrutiny especially when considering the dollars likely involved on this auction. I'm looking at a copy of a Baltimore buildsheet on an LS5 built one day earlier than this car and there are some differences that could be questioned. Also, would be the first LS5 buildsheet I've ever seen w/o the T60 HD Battery being listed.
Dick
Old 07-05-2006, 05:50 PM
Call me paranoid but the font on the build sheet doesn't look quite right.....close, very close, but just not quite right Beautiful car nonetheless, and excellent pictures
Bill Pritchard
Old 07-05-2006, 06:17 PM
I can't see the Buildsheet on this screen at all.It's too dark & far away,so I can't comment on it.
Lakewood and all the other 6 Assembly plants built these in convertible form.Final destination did not determine plant built at.
No LS-5 Chevelle/Elco recieved the 4:10 posi rear on the assembly line floor.They recieved either a 3:31 open,(RU) or a 3:31 posi,(RV).Air conditioning had nothing to do with that.The 4:10 Posi was a solid Lifter engine application...L-78 & LS-6 ONLY.
The seller does not state anywhere that is the ORIGINAL 4:10 rearend,...but the CKK coded 4:10 posi was an 1970 L-78 Chevelle/Elco application only and with a date of 03 23 makes me believe it was stamped to fit the time zone of this particular Chevelle.I would like to know the casting No. & date of that rearend housing.. I would be suspect of that P-O-P for this reason alone.
Although the literature from back then does suggest that the New T-60 Side terminal R-79W battery must be ordered with the New 454's,examples do exist today that show they were ordered with the R-59 Top post battery origianlly.It was not as Mandatory as they led us to believe.
The incorrect stainless pedal trim and other hicups I see aside,I think this Chevelle is a nice looking ride as it stands.
Definitely a fake build sheet!!!!
The font is wrong as Bill pointed out. The tears in the paper are exactly that...a tear. Look at the torn edge and it's white wear the color didn't soak into it. brittle paper doesn't have that same "torn" edge. but there is a dead givaway. Compare the "STATEMENT OF ACCEPTANCE BY CARRIER" in lower right hand corner and compare it to a real build sheet.
Don't mean to talk in code but don't want to help make the fraud's better!
Howard
Old 07-05-2006, 06:51 PM
budnate's Avatar
budnate budnate is offline
Couple of questions. Was the open element AF available for the LS5? Did the Lakewood plant make convertibles? If so why would a Florida delivered (per BS) LS5 vert come from Baltimore. Not throwing any spears here. Just curious. Nice looking car.
Thanks
Sam-
side note on paper - not to change the subject, I have the orig window sticker for the T/A that shows the car was/?? delivered on the east coast new and was factory transfered out here to Seattle, kinda odd but its the original sticker and it shows the transfer at the top of it. I guess it was re-routed for demand by GM???
any dealer trade I have ever seen they sell it with the sticker with the original dealers name on it,just a interesting tid bit to file away.
now back to the Chevelle.
Old 07-05-2006, 08:05 PM
JIM's Avatar
JIM JIM is offline
My 70 SS conv was built just before this one. Its a real Black, black saddle 4 spd. Build sheets are way different. Need help to post picture ideas??? Jim
Old 07-05-2006, 08:20 PM
Late BrakeU2 Late BrakeU2 is offline
Jim,here's a thread with over two thousand hits on this subject-
http://www.chevelles.com/forums/showthread.php?t=134511
I feel very strongly that we should refrain from posting legitimate sheets-these guys are very close already,and every time we provide another blueprint the time will soon be at hand when there will be no way to tell the diff.
JMHO
chads454Ls6 chads454Ls6 is offline
It is becoming scary how well they are starting to fake the sheets. As pointed out earlier,the font is incorrect and not dark enough. Several issues with the codes as some are not correct for the car. No sense pointing them out as the person that made the sheet could be reading this. Not to say they wont find out eventually,but why help them.
Old 07-05-2006, 10:58 PM
BUIZILLA BUIZILLA is offline
Please don't shoot the messenger here.... i'm just factually stating what I know here as of TODAY. I did some easy checking on the Dade County, Fla. property tax rolls, and other things, starting from 1955, which is when I moved here...
927 Andora Ave. on the POP, does NOT exist, never did, 915 and 931 do exist on that side of the street, 920 is on the other side of the street. Homes are still in place, originally built from 1955-1964, and still there today, nothing has changed in 40-50 years there.
Don Allen Chev. was at 2050 N. Miami Ave, the corner of 20th St and N. Miami Ave., the lot still exists. Not 2245, which is two blocks down, and on the other side of the street. The correct zip was 33127, not 33727, as shown on the build sheet.
Box 94 shows a rear speaker, however the balance knob for it is missing on the radio, and there is NO rear speaker...
The axle tubes are welded at the pumpkin, and ground down smooth, draw your own conclusions here...
ditto on the no 4.10's rule, didn't happen...
alternator pulley is for an LS6 ?
A/C compressor clutch is for a GS Stage 1 or a W30 Olds...
I see at least 2 or 3 other build sheet *issues*, one very obvious, but I ain't sayin' nuttin more...
Jim
aka - Mighty Mouse
Old 07-05-2006, 11:14 PM
Ngtflyr Ngtflyr is offline
The main reason I originally made the post was that I felt the BS was a very good aged one (scary) with a couple discrepancies. The car "came" with everything one could desire, knowing what I know now and using a time machine I would go back and order it pretty much like it was restored, well maybe throw in a LS6 while I'm at it. Everyone here did not disappoint, thanks to all for the verification. Additionally, my thinking was that a car like this would be known to someone on this board from the local area.
Dave
