Old 07-03-2006, 09:10 AM
Late BrakeU2 Late BrakeU2 is offline
Default Re: Engine knock
I recall straight water down the hatch with some rpm used to do the trick.
Old 07-04-2006, 07:57 AM
Didn't we used to pour auto trans fluid down the carb while running to get rid of carbon ? Makes lots of smoke.
Yes we did Charley, but it doesn't do the trick nearly as well as water. Can really stick to the carbon and gum things up.
Straight water is the best method for breaking up carbon on top of a piston. Keep the revs up, and pour it straight down the front two barrels of the carb, alternating slightly from side to side. You can even trickle it with a garden hose. You will get a feel for how much it can take as you go, but start slowly. Not sure how to describe how much it can take. Obviously, if you over do it, you will cause a hydro lock, and have really serious problems.
Lynn
