Old 04-08-2006, 06:35 PM
Default 74 Z28 stuff
-----These arent the highest demand pieces but thought maybe someone on the board could use them before I E-bay the stuff.
-----Complete 1974 Z28 induction set-up. Came off a 30,000 mile extremely clean, unmodified car about 6-7 years ago. Been on a shelf in my garage ever since. Could this stuff also be right for a 73 Z28, other than dates???
-----1. Cast iron intake. good condition, just dusty with a few gas stains, etc.
-----2. Quadrajet, clean just dusty. Probably need a quick going thru from sitting. Throttle linkage bracket still on carb.
-----3. Air-cleaner. Mint with exception of the lid neading a re-chroming. Valve-cover tube and AC element still intact. even has carb gasket.
-----4. Original fuel-pump and correct fuel-line.
-----5. Original power-brake hose and hard line with the two spring clips
-----6. Original 74 aluminum valve-covers. These have been polished and clearcoated. A couple of small areas of corrosion have crept thru the clear-coating. Have original bolts for these as well as all the spark-plug looms that the car had.
-----Numbers 1 thru 5 should sell as a unit. Asking $500.00.
May separate if no interest is shown in the package.
-----Valve-covers, looms, and bolts. Asking $150.00.
-----Will knock off some bucks for all, and want to give a portion back to the website for the opportunity. Theres some weight here so think about shipping problems. 810-326-0490.........Bill S
