Old 04-04-2006, 12:16 PM
firstgenaddict's Avatar
Default Re: WD-40
Works great as the explosive propellant / lubricant for a Potato Gun.
~JAG~
NCRS#65120
NUMEROUS Lemans blue Camaros,
& a Chevelle or two...
Old 04-04-2006, 07:33 PM
Default Re: WD-40
In college, one of my buddies set up a potato gun out of 2 sizes of PVC sewer pipe and a sparker from a gas grill. He found that Rave Extra Hold #5 hair spray was the best propellent, just had to clean the ignitor off after a couple of rounds!
1969 Hurst/Olds
13.26 @ 103.12 Pure Stock
Rusty Small
Old 04-04-2006, 08:36 PM
Canucklehead Canucklehead is offline
Default Re: WD-40
I found starting fluid worked better!, but we were shooting grapefruits mind you!
Old 04-05-2006, 09:17 AM
Default Re: WD-40
We had the same problem Rave gummed it up... WD40 acted as a barrel lubricant. Awesome... used to shoot it off the roof of the Fraternity House at another's House across the street.
Cops finally came ... No Chrome braclets but they took the Spud Gun... probably to play with themselves!
~JAG~
NCRS#65120
Old 04-05-2006, 06:31 PM
Default Re: WD-40
My buddies fired off a tennis ball inside the house in the long hallway. Needless to say, it came back at a rapid rate! They got out of the way, but the window did not! Perfect hole through the center of the plexaglas! They also used some other projectiles and fired off toward the dorms. Something to the tune of 2-300 yards!
1969 Hurst/Olds
Rusty Small
Old 04-06-2006, 03:24 PM
67 GTO 67 GTO is offline
Default Re: WD-40
WD used to be great for flamethrower antics, but they've changed it since. If the rolled edge (top) is narrower than the can, it's the less flammable stuff. A rolled edge that protrudes slightly is the older, and therefore better, stuff.
This is just a small excerpt from my non-existant book: How To Spot Good Stuff At Garage Sales - Pyro Edition.
Old 04-06-2006, 08:46 PM
Default Re: WD-40
While at a Salvage yard recently,I was trying to remove some pulleys from an engine.I couldn't get the bolts to move,so I asked the attendant if he had any WD-40.
He comes back with something called AeroKroil,that quickly freed up all the bolts as well as other items on the engine.
I was so impressed with it,I wrote the contact info down... HERE.
This stuff is like WD-40 on Steroids!
Old 04-07-2006, 07:45 AM
Default Re: WD-40
Yea but does it use PROPANE as a propellant?
~JAG~
NCRS#65120
