Old 03-30-2006, 01:56 AM
Jim Ferron Jim Ferron is offline
Default Re: 12 bolt shoppers beware !!!!!!
Jeez, I've known guys to redrill 10 bolts to 12 bolts for YEARS! I actually did it the other way around in my 66 GTO.. 12 bolt with a 10 bolt cover...[actually kept the 12 bolt cover just filled the big whoop with bondo...and drilled new holes]
www.68hurstolds.com 'Russ Dunmire Hurst Olds'
www.classicperformance.com 'Cars'
Old 03-30-2006, 05:55 PM
GM-26's Avatar
GM-26 GM-26 is offline
Pretty bad feedback on the seller.
Member Profile: btuff99 (28)
Positive Feedback: <font color="red">86.8%</font>
Members who left a positive: 33
Members who left a negative: 5
All positive feedback received: 33
Nick...
Old 03-30-2006, 08:26 PM
A fast question if you please.
12-bolt rears actually refer the the number of bolts used to
affix the ring gear to the carrier - correct? Are the 10
bolt and 12 bolt housings the same size? Can a 12 bolt
carrier be installed in a 10 bolt rear? I wouldn't think
so. Can someone just clarify for me?
Jim, why would someone disguise a 12 bolt rear as a 10 bolt?
I'm lost on that one.....
Steve
Old 03-30-2006, 08:30 PM
427TJ's Avatar
427TJ 427TJ is offline
Pontiac used 10-bolt rears. He probably wanted the stronger Chevy 12-bolt but wanted also to fool the under-car peekers.
Old 03-31-2006, 01:10 AM
You know, I don't want to bash the Pontiac's as I personally
like the 69 GTO &amp; 70-73 Formula's, but what gives with
Pontiac? Ram Air IV with a Rochester carb, 10-bolt rear?
Did Pontiac know something the rest of the car makers didn't
or did they not know as much? At least the RA4 got an
aluminum intake...
Steve
Old 03-31-2006, 03:05 AM
Steve
[/ QUOTE ]For the same reason I hade two sets of gaskets under the valve covers....[can anbody figure that one out?]
Of course TJ427 is right on the rear, but who can figure out the valve cover deal?....
[I'll be back with the answer right after a few words from our sponsors...]
Old 03-31-2006, 03:10 AM
Roller rocker clearance !
Old 03-31-2006, 06:45 PM
Nope, try again...1966 GTO, why two gaskets under the valve covers gaskets...hint: what's he hiding?...anyone? anyone?...
Old 03-31-2006, 07:43 PM
PeteLeathersac's Avatar
Stud girdles?
~ Pete
Old 03-31-2006, 08:05 PM
thesupernova86 thesupernova86 is offline
hmm...extra room in the valve covers??? are we smuglin drugs?...lol.. saw that on tv once.. guy had a car and was pullin in on a trailer... guts of theengine were cut out and it appeared to be a runing car... but the motor was full of heroin!
