Old 12-27-2005, 02:37 AM
Default Re: Question about VIN stampings
I know our old 69 Impala convertible (built at the St. Louis plant) had the CON VIN stamped under the blower motor housing on the firewall.
Bill Pritchard
Old 12-27-2005, 07:00 PM
JohnZ JohnZ is offline
Here's a typical engine/transmission VIN derivative gang holder, where one (or more) digits were manually changed for each job as it came down the engine dress line; each individual character die had a slot milled in one side, and the spring clip kept them from falling out:
Here's a typical air-powered frame VIN stamper - it clamped to the frame rail and stamped the top surface, normally in two places:
The body/cowl stamper was made by the same company (George T. Schmidt Co. in Chicago), but was a multi-segment indexing "egg-stamper" mounted on a swiveling bail like a spot-weld gun; the "egg" rolled one way for the cowl impression, the tool was re-positioned to the heater opening, and it rolled back the other way, and was then indexed one digit for the next job.
'69 Z/28
Fathom Green
CRG
Old 12-27-2005, 07:19 PM
Incredible...Great pics & info Mr.Z
Thank You for sharing.
Old 12-27-2005, 07:22 PM
Belair62 Belair62 is offline
Great pics.....
Old 12-27-2005, 07:32 PM
Jeff H Jeff H is offline
Thanks John Z, I figured you would have the detailed answer.
Old 12-27-2005, 07:57 PM
Great pictures John. Any chance you could share other assembly line photos. I am amazed at how many myths these photos can dispell. Thank you for sharing them with us!
Rick
Old 12-27-2005, 10:44 PM
Neat pics, John, thank you for the info
Bill Pritchard
Old 12-27-2005, 11:59 PM
firstgenaddict's Avatar
My Pontiac built 68 GTO has no VIN on the frame nor does it hav any hidden VIN's that I can find...
~JAG~
NCRS#65120
NUMEROUS Lemans blue Camaros,
& a Chevelle or two...
Old 12-29-2005, 10:13 AM
Rainer Rainer is offline
If the body VINs were stamped as described above, what are the thoughts on the cowl stampings of this LS6 rag on ebay?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=4599998347
1969 Chevelle SS396 L78 M22 4:10 Tuxedo Black
1970 LS3 Malibu 400 BB convertible
1970 LS3 Malibu 400 BB coupe
1970 Chevelle 300 series LS3 400 BB coupe, special order Monaco Orange
1970 Chevelle Concours Estate LS3 400 BB wagon
1970 Chevelle SS396 L78 M21 3:55 Tuxedo Black
Old 12-29-2005, 06:57 PM
My thoughts are that I would be suspicious of those stampings. The sheet metal looks pretty distorted in the stamped areas. Perhaps the Los Angeles plant used a different stamping method on the bodies
Bill Pritchard
