Old 12-15-2005, 08:01 PM
Default Re: What paint to use for Restoration??
Bring back Al Fierke...
Old 12-15-2005, 08:49 PM
DarrenX33's Avatar
Al was there....
1969 Z28
1972 Corvette
Old 12-15-2005, 09:27 PM
hvychev hvychev is offline
My Deuce is painted in Laquer and I hate it. It is a lot more maintience than regular BC/CC paint since I drive my car. The only thing that is good about it is it is a lot easier to touch up or "repair" the paint should you ever have a mishap. I bumped the back of my Deuce while parking it over a year ago cracking some paint off the car. Luckily I still had some of the original DuPont Laquer that the previous owner painted my car with. I brought it to the right guy and he fixed it so well that I can't even remember where I bumped it!
Frank Magallon
Old 12-16-2005, 12:20 AM
MosportGreen66's Avatar
In the NCRS a major deduction in paint scoring occurs if the car is painted in BC/CC; even if you have made an honest attempt to dull BC/CC (appear as if it were lacquer). The door jambs, head light buckets and rear valance should all be lack luster areas (among others). Virtually every car that makes it to the highest of possible levels in scoring and showcasing (high point Top Flights and special collection cars) all have original lacquer paint. It is far more superior for the stickler restoration. Commonly you will find the Corvette owners who paint their cars in lacquer will bring covers to shows and park their cars in those plastic climate controlled bubbles. When dealing with Corvettes, your car has got to be 100% dead on perfect to win high prestigious awards with BC/CC. It is very costly and very hard to find a guy who will paint using lacquer today. The paint contents are known carcinogens.
Old 12-16-2005, 05:09 AM
Enoch Enoch is offline
Banned
I am currently doing frame off's on 3 67 435 corvette convertable's and 2 are going lacquer and one going single stage red. The lacquer paint is not as hazardous as the newer paints with Isocynates. I will not give a guarantee
on lacquer. As the paint manufactures do the same.
Old 12-21-2005, 03:44 PM
I find that Lacquer is very easy to work work with if you know the product. The main problem I find is thinning it the proper amount with the correct thinner to get that flow out just right and setting the gun flow properly. In Houston with the high humidity, the paint was frosting up due to condensation so I ended up using a retarding type thinner to slow the drying time, and it worked, giving that factory type finish. Due to the high VOC's, it has been outlawed since the late 90's but still can be had if you know where to get it. I have tried enamel based paints and the look just does not match my original paint Lemans Blue 69 SS.
Paul
Old 12-23-2005, 05:36 AM
Stefano Stefano is offline
Lacquer paint today is not of the same chemical composition as it was back in the day. I am not a chemist, but the main component missing is lead. It is not as durable nor is it as flexible as it once was.
To paint a car with a named product that is inferior to that which was applied by the factory, to appease show judges makes no sense to me.
Solid colors done w/single stage paint can provide for quality paint jobs and great repair ability.
BC/CC is the way I would go. But I am one of those guys who doesn't care about putting factory runs and panel miss alignments back into my cars.
Old 12-28-2005, 12:21 AM
firstgenaddict's Avatar
I have said it before and will say it again... If you were to travel back in time to 1967 buy a brand new camaro travel back to the present... drop it in a car show, it most likely would not even place... in a local show... (I believe this to be true for all except Corvettes)
Now that is what is SAD!!!!
~JAG~
NCRS#65120
NUMEROUS Lemans blue Camaros,
& a Chevelle or two...
Old 01-02-2006, 08:09 PM
SMGCO SMGCO is offline
You also need to check on the legality of shooting laquer in your state.
Old 01-06-2006, 08:13 AM
[/ QUOTE ] Frankie, was the repair really that unnoticeable or were you just sniffing the leftover can of lacquer?
