Old 12-02-2005, 03:17 AM
Pat O'Connell Pat O'Connell is offline
Default Re: Camaro funny car
Definitely a challenging restoration!
Pat O'Connell
Old 12-02-2005, 03:27 AM
Jacsey 70Z Jacsey 70Z is offline
Looks like half the car is turning right and the other half is going straight!!
Jack Seymour
1970 Z28
Hugger Orange
20K Mile Survivor
Old 12-02-2005, 04:24 AM
396L35's Avatar
396L35 396L35 is offline
Something tells me that car is going to need a alot more than some repop sheetmetal... what the $@!* happened to it???
Joe they shipped it on that small pallet under the car and it looks as if the car shifted in route..
Mark
Old 12-02-2005, 04:28 AM
camarojoe's Avatar
Oh, I thought those were a set of Swedish wooden ladder bars.
Joe Barr
Old 12-02-2005, 07:44 AM
It appears that the back 2 frame to body bolts are either not there, or have pulled through the floor. The front bolts appear to be there in some form. Maybe. You can most likley save it, but it's gonna be expensive, and very time consuming as I'm sure there are multiple issues that we can't see.
You may want to consider another project that is less material, or labor intensive. If not, good luck, and get friendly with your good mark dealer. If you need a full floor, the dii's fit well.
Old 12-02-2005, 08:15 PM
Mark, you are right about me making a decision here. If I keep it I will make it look original, so I want good quality. And I also saw it as a good testvehicle (not so good anymore ) before starting on my COPO. Therefore I want to use the same sheetmetal on this car as on the COPO. I might have to change my mind on this though.
I might add that the frontend problem looks worse than it is. The subframe just wasn´t bolted to the unibody correctly. The problem is the floor and rear part of the body. Before they started working on it, I don´t think it was much worse than COPO-Pete´s white racer before it was restored.
Schonye, like you said, there are multiple issues to consider. If I could find a car here in Sweden that I could cut the back-half off, it would save me some time. But I don´t think there is such a donor-car around.
What is dii´s web address by the way ?
Anders Stålklint.
