Old 10-21-2005, 10:38 PM
Rick H Rick H is offline
Yenko Premier Member
Default Re: Engine pad decode
I got thinking about this engine stamping and went back to review some docs and talk to a few Corvette people. Some docs I reviewed had body sequence listed and others had VIN sequence listed.
No matter which way you look at the stamp it is incorrect whether it be body number or VIN number. VIN,s for 67 Corvettes didn't go that high. Plus Corvettes did not include the assembly plant code in 1967 in the pad stamp. That started in 1968.
I got to believe that the stamp is not legit.
It could be a big car motor that had the engine code changed. It's easy to change a "J" in to a "U".
Just doesn't add up.
Rick H.
Old 10-24-2005, 05:55 AM
With a final winning bid of $7499.00,I would say someone knows exactly what this is.
Old 10-24-2005, 12:14 PM
jfkheat jfkheat is offline
More that it was worth to me.
James
1968 Beaumont SD396
Old 10-24-2005, 05:05 PM
COPO COPO is offline
If it was really one of the 16, it would have been many times more than the final bid. My guess is someone took a chance on it.
Old 10-24-2005, 05:42 PM
PeteLeathersac's Avatar
Does anyone recall in the Vette crowd close to 20 years ago an IU motor (an actual one) showed up loose....the guy tracked the car down, bought it rough and sold the match for a ton? . If this eBay one was genuine, considering the value of these cars it would have sold for much more to someone in the know?
Old 10-24-2005, 08:02 PM
TimG TimG is offline
Jerry Luck found the original engine for this car and searched to reunite it with the car. It used to be owned by Kevin. http://www.proteam-corvette.com/cars/NSN-DM67.htm
Typical '67 big block stamping should read like this, TO613JC 7121526 (from my car)
In '67, they did not have an "S" in the VIN portion. They used smaller VIN numbers starting in '68 and included "S" in the VIN portion. Lots of questions on this stamping from the little I can see.
