Old 09-11-2005, 07:05 PM
Default Re: Correct Color for 1970 Z28 Wheels
-----Hey Kid,,,,,,,,You are correct, sir! My eyeballs must have been inside-out. Saw it right away after you posted, but didnt have a clue till then. You guys must have thought I was seeing things, and actually I think I have been. Had a minor operation (per the doc) that doesnt seem so minor and Ive been wolfing down percocets. My bad!!!.........Bill S
Old 09-11-2005, 07:36 PM
Phil, One of the components of the PPG LAQUER formula is SUEDE ADDITIVE, which achieves the "rough" finish of the Factory Original finish. I cant suggest exactly how to apply with what technique, but I would THIMK the suede additive accomplishes the desired effect.....
Chuck
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
Old 09-11-2005, 09:46 PM
I suspect that is the same Suede Additive that was originally used to paint the top portion of metal dashboards on 69 cars. They have that slightly 'rough' texture.
Bill Pritchard
Old 09-11-2005, 11:25 PM
In fact, I will be painting mine soon. Here is a shot of my 70 Z28 original spare tire/rim, showing the color.
I will drop it by my local PPG distributor and have them match it. There is also a rough like texture to it, simulating a cast mag wheel.
Anyone know where you can get the trim rings?
Paul
I am not sure but the finish on this wheel looks too smooth to be original paint and the shade looks off.
72 SS 350 4spd Camaro
74 Z28 Automatic
80 Z28 4spd
94 Z28 Automatic
Old 09-12-2005, 08:42 AM
If you get close it has a rough cast aluminum look to it. I will take some close up shots tomorrow.
Paul
Old 09-13-2005, 01:02 AM
Jacsey 70Z Jacsey 70Z is offline
Here are a few pictures of my spare thats never been mounted. It looks a little to gold color but I think that's because the flash went off. The inside if you look close you can see the overspray from the gray paint, showing the gray was painted last and NOT masked. Last pic is one mounted on the car note the correct lug nuts, embossed center cap, 5/8" valve stem hole (70 only up till about may, june) and valve stem extension and original tire.
Jack
Jack Seymour
1970 Z28
Hugger Orange
20K Mile Survivor
