Old 09-08-2005, 01:10 AM
Default Re: 70 Z28 LT-1 Cam questions
Set it per the cam card, you'll be changing it later anyway if you are 'super-tuning' for SCR9 Racing
Old 09-08-2005, 02:27 AM
Belair62 Belair62 is offline
Where is this link to John Z's method...tired of burning my freakish hands !!
Old 09-08-2005, 02:37 AM
TDW TDW is offline
"30-30" AND OTHER OEM SB SOLID LIFTER CAM VALVE ADJUSTMENT
By John Hinckley and Duke Williams
The traditional method of adjusting valves one or more cylinders at a time with each cylinder at TDC is fine for hydraulics and for most solid-lifter cams, but NOT for the factory "30-30" solid-lifter cam used in '64-'65 L-76 327/365 and L-84 375hp (F.I.) Corvette engines (and in '67-'69 Camaro 302/290 Z/28 engines); this cam has VERY long clearance ramps that are .020" high, and at TDC for any cylinder, both the intake and exhaust valve for that cylinder are still on their ramps, NOT on the cam's base circle, which is why the Service Manual for all cars so equipped says specifically to set them "hot and running".
There is, however, a better way to adjust the valves with a "30-30" - you can set them "cold and not running" by setting the intakes at 90 degrees ATDC and the exhausts at 90 degrees BTDC - so the lifters are on the base circle, not on the ramps. This has been confirmed with cam lift/crank-angle diagrams, and I've done mine this way - results in a nice mechanical "singing" sound, no "clacking", it runs better, sounds better, idle is more stable, and throttle response is improved. Many other Corvette “30-30” and Z/28 owners have followed this procedure as well since we developed it, and all of them have seen the same positive results.
Set them cold at .026"/.026". The actual measured (stamped rocker arm) ratio at the lash points is actually about 1.37:1 (not the design 1.5:1, which is a theoretical max lift measurement - actual measured max lift with factory stamped rocker arms is about 1.44:1), so the clearance ramp, which is exactly .020" high on the lobe, is all taken up at .0274" clearance; .030" clearance with the valve closed is too loose - the ramp ends/begins before the .030"clearance is taken up, resulting in the valve being lifted off and returned to the seat at greater than ramp velocity. This will contribute to valve seat recession, and can cause valve bounce at the seats at high revs - it will also be noisy.
You can adjust two valves at each 90-degree rotation point, starting at #1 TDC, turning the crank 90 degrees at a time seven times (measure and mark your balancer first at 90-degree intervals from TDC). Removing the plugs simplifies rotating the crank, but you were going to change them anyway, right? Proceed as follows:
TDC #1 - 8E, 2I
90 deg. - 4E, 1I
180 deg. - 3E, 8I
270 deg. - 6E, 4I
0 - 5E, 3I
90 deg. - 7E, 6I
180 deg. - 2E, 5I
270 deg. - 1E, 7I
Start at TDC #1, then rotate 90 degrees at a time, setting at .026" cold. If you like, you can then go back after you're done to each cylinder's TDC position and check clearance on that cylinder's two valves, and you'll find that they've closed up to .024", indicating that both valves are still on the ramps at TDC, as I pointed out in the beginning.
Trivia - the point of max inlet lift on the "30-30" cam is at 112 degrees, with a lobe separation angle of 114 degrees (angle between points of max lift, not the geometric center of the lobe - the lobes on the "30-30" cam are asymmetrical).
This progressive procedure will ensure that you are on the base circle on ANY OEM Chevrolet cam for adjustment, and the factory-recommended clearance on other OEM Chevrolet small-block solid-lifter cams should be factored as well by the 1.37:1-vs.-1.5:1 ratio difference at the lash point and rounded-down to the next-nearest thousandth or two to ensure that the valves are picked up and seated at ramp velocity.
What about the original “097” Duntov (used from late ’56 to ’63)? The “097” Duntov was designed for .012”/.018” clearance with 1.5:1 rocker arms, but in 1963 the intake clearance was revised to .008”, and this was also recommended in Corvette News back in the late 50’s for “weekend competition events”; the tighter intake clearance gave a bit more effective inlet duration. Factoring the original .012”/.018” by the 1.37/1.50 rocker ratio correction yields .01096”/.01644, call it .010”/.016” (hot), so if you’re already running the .008” intake clearance, it shouldn’t be tightened any further. We recommend a (cold) setting of .010” intake and .015” exhaust for 283’s, and .008” intake and .015” exhaust for 327’s. A complete crank angle/cam lift diagram in Corvette News, Vol.8, No.4, indicates that neither the exhaust nor the inlet is on the clearance ramp at TDC of the firing stroke, so you can use the indexing procedure outlined earlier, or it’s also OK to adjust both the inlet and exhaust at TDC #1 and TDC #6 as outlined in the 1963 Corvette Shop Manual with the “097” Duntov cam; it has much shorter ramps than the “30-30” or the LT-1.
What about the later early-70’s “LT-1” solid-lifter cam? In the case of the LT-1, it’s OK to adjust the intakes at TDC (its closing ramp ends about 10 degrees BTDC, so it’s off the ramp at TDC), but the exhaust is still on its ramp at TDC, so the exhausts should be set at 90 degrees BTDC using the indexing procedure. Both intake and exhaust recommended clearances should be factored down by the 1.37/1.50 rocker ratio correction here as well, from the factory spec of .024”/.030” (hot) to a (cold) setting of .021” for the intakes and .026” for the exhausts.
The difference between “hot” (engine idle speed) and cold clearance on a cast iron pushrod engine is negligible, so clearances can be set cold, which is much more convenient. The clearances noted are derived by “factoring” the OEM recommended clearances by the ratio 1.37/1.5 to compensate for the actual measured rocker arm ratio of 1.37 at the lash point. That number is then rounded down. The factory clearances are derived from multiplying the maximum height of the ramp above the base circle by 1.5. When running hard, such as at sustained WOT, the exhaust valve head heats up considerably. About 80% of exhaust valve cooling is through the seat, but the stem temperature will increase also, which causes the stem to grow and decrease running clearance. This is why exhaust ramps are typically higher than inlet ramps - to allow for more stem growth and still maintain some running clearance to ensure that the valves seat fully. Since the intake valve is cooled by the incoming fresh intake charge, its temperature and clearance will remain more consistent over the entire engine operating spectrum.
The rocker arm nut should be tightened until a light drag is felt on the feeler of the same thickness as the recommended clearance. Then the clearance can be verified by inserting a .001” thicker feeler; if it won’t go, the clearance is between the two gages, which is just right. Normal engine service will usually result in slight loosening of clearances over time, and Chevrolet service recommendations from the 60’s recommend a lash check every 12,000 miles as part of a normal tune-up.
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
Old 09-08-2005, 03:31 AM
Man, how's that for information. Would you have the cold lash settings for the 70 LT-1 cam? Could you take .004" off of the hot lash settings? (Never mind, I read further)
Paul
Old 09-08-2005, 05:04 AM
[/ QUOTE ]Marlin, are the replacement cams generally the same setting as the original cam for the same application? I guess I better look at my cam card. We have been setting my replacement 302 cam at 30/30. AH who cares, 302's don't run anyhow!
Old 09-08-2005, 06:09 AM
JRSully JRSully is offline
any of these tips for an L78 BB.?
71 Porsche 911 Targa
Old 09-08-2005, 07:41 AM
Chevy454 Chevy454 is offline
24/28 there, Sully...set the intake as the exhaust opens, set the exhaust as intake closes...
Old 09-08-2005, 07:52 AM
TDWZ28, just set the valves per your procedure and it worked great. Thanks,
Paul
Old 09-08-2005, 04:32 PM
That's the procedure I used after breakin, works great!
Old 09-13-2005, 10:34 PM
My GM blueprint cam card has 20/24 - hot. The file is too big to attach
