Old 09-06-2005, 10:02 PM
enio45 enio45 is offline
Default Re: 67-69 camaro hinges
Looks like i need help from Bill D!!! Come on BILL!!
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 09-07-2005, 03:35 PM
BillD BillD is offline
Ed, I will try to find them this evening and then post a picture here to let the guys that know the difference between the years make sure what I have are really for a 68.
Old 09-07-2005, 08:55 PM
Great Bill, anxiously waiting!!
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 09-07-2005, 09:27 PM
Rick H Rick H is offline
Yenko Premier Member
Here is what I looked up. Forget the 67's they are different. 68 and 69 have different part numbers but may work. They are different in appearance. The 69 has a rounded off ends located where the pin goes through and the 68 is more squared off.
The 68 part number calls for 68 Camaro only while the 69 part number calls for 69 Camaro and 68-74 Nova.
I know there is something else but I can't remember right now. When you place the 2 hinges together they look the same but the physical appearance will be obvious.
Confusing huh?
Rick H.
Old 09-07-2005, 09:39 PM
The hinges have stamped numbers on the two pieces. I have some information on them at home and I'll look for it tonight. I'm a CRG member and maybe we need to put together an article on the hinges.
Martin Foltz
68 Camaro SS-396
Old 09-08-2005, 03:42 AM
OK, the most difficult part of this job is done, I have found the hinges and it looks like I have more than a complete set, some of them have part number tags still on them. I also found a bunch of other stuff that I forgot I had. If I have time later I will try to take a picture and then see if I can remember how to post it
Old 09-08-2005, 11:31 PM
Gets more interesting.....thanks for the leg work...i cannot visualise the difference mentioned, maybe the pics would be help. Is this an item looked at on a 1000 point judging??
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 09-09-2005, 05:39 AM
Here are my notes:
68 LH door, upper: stamped 2699L and 2700C
68 LH door, lower: stamped 2703L and 2705L, spring bkt 2663
68 RH door, upper: stamped 2698R and 2700C
68 RH door, lower: stamped 2702R and 2704R, spring bkt 2663
69 LH door, upper: stamped 2699L and 2701C
69 LH door, lower: stamped 2703L and 2707L, spring bkt 2663
That's all I have, hope it helps.
Martin Foltz
68 Camaro SS-396
Old 09-09-2005, 10:24 PM
Some numeric difference, probabaly as Bill indicated in the look....anyone with the 69 RH numbers??
OK then the question, they still work on either yr??
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 09-10-2005, 08:39 AM
Ed, I will try to get a picture or two posted on Saturday. I was planning on doing it this evening but it just never happened.
