Old 07-02-2005, 09:02 PM
Default Re: 1969 L78 Camaro Radiator
Looks like the general consensus is the ZD 3 core. Has anyone ever found a buildsheet up in the headliner? My car was a Norwood built 04C model.
Paul
Old 07-03-2005, 06:21 AM
CJP_69 CJP_69 is offline
Paul,
No build sheet on mine either but the pacer is a Norwood 04C also.
Chris
Old 07-03-2005, 09:37 AM
What are the #'s on your engine, mine was T0417JH.
Trans: P9D11B
Rear BV0417G2 E
Paul
Old 07-08-2005, 07:38 AM
Paul,when I located the car it had a "cobbled up" 427, but still retained its original 837 alternator, 499 distributor, deep groove pulleys, harrison radiator, M-21
and rear. My M-21 is also P9D11B and the rear is BU0415G2.
I located a date correct JH motor and that has been installed.
Chris
Old 07-08-2005, 08:08 AM
Wow, both transmissions built on the same day! Cool
What are your dates on the Alternator and Distributor?
Paul
Old 07-08-2005, 09:34 PM
The 837 is 9 D 3 and the 499 is 9 B 12. The distributor looks just like the 499 in Jerry MacNeish's 1969 Z28-SS396
fact book where the "B" strike is lighter than the other characters. Maybe it was a little worn.
Chris
Old 07-08-2005, 10:07 PM
ssl78 ssl78 is offline
My L78 Pace car was built 03B engine stamp is TO311JH trans is P9B14B rear is Bv0314G. It seems the drivetrain has never been removed from the car.
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Chevelle conv
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
Old 07-11-2005, 12:15 AM
LS6 RAT LS6 RAT is offline
My L78 Burgundy convertible showed ZD on the chassis broadcast copy that came off the fuel tank (Van Nuys built), however the car had a curved neck radiator. Drivetrain is M20, 3:55 ratio.
2 1971 LS-6 Corvette coupes (Duntov's last stand)
Old 07-11-2005, 08:49 AM
LS6 RAT - Is it the original Harrison Radiator? If so, GM must of had a shortage of ZD radiators and substituted the curved neck 4-core.
Paul
Old 07-16-2005, 06:51 PM
SSJunkie68-69 SSJunkie68-69 is offline
My 69 L89 Camaro has a 3 core ZE coded Harrison Radiator with a straight neck. It has been my understanding that all Copos and L34/L35 Cars (with AC) recieved curved neck. Also that all ZD and ZE code radiators are straight necks while all UY and UZ code radiators are curved necks.
Hope this helps......have a great weekend~
Tom
