Old 01-05-2005, 06:06 AM
NCGuy68 NCGuy68 is offline
Default Re: DZ302 engine horsepower rating
One year they really hammered the rating on the 302 because it was winning too much.
Yep....the little small block that could out run the big blocks in "D" and "E" Stock Class way back when NHRA was for 'grass roots' guys and not "Pros" as is today. Same thing happened in the late 60s when NASCAR outlawed the Hemis. Said they made too much power and don't bring them back! Go tell Richard Petty that!
Craig S.
"I saw Elvis At 1000 Feet"
John Force.
Old 01-05-2005, 04:00 PM
In 2004 NHRA rated the D and E Stock 302's at 305 H.P. Too much H.P. rating for there class because they had to run the low compression 351 fords with low factory ratings. Made the 302 fast but not always fast enough to win class. It is all about how NHRA rates the motors. Getting back to not feeling fast.....Mr. Adams is correct! ALL Z/28's need M20's and at least 4:10's to pull away from a traffic lite. Most all old magazines feel that the Z in factory form is 325-350 h.p.
Old 01-06-2005, 10:31 AM
68TopStock 68TopStock is offline
My 302 with the crossram is totally stock, with std bore etc. It dyno'd at 359hp. If the xram is worth 25hp, (per factory) then mine would be 334 hp with a 4 bbl. I run an M20 with 5:38's. This year my best 60' time was 1.80 and e.t. 13.01.
Guys were running 302's in the early 70's at 11.00 flat in AHRA. Gene Dunlap had these times with his Harrell 302 GT racer. I calculated that my car had around 450hp when Fred had it, based on a weight of 3200 lbs, and times of 11.75 in the 1/4.
ps. I have only driven one other car that was as much fun to launch and shift, and that was Matt's DH proto #2. Neither feel "slow".
Old 01-06-2005, 05:34 PM
Ken, The 538's say it all with a 254 first gear! In the mid 70's when my friends, Pete and Ron set the G/MP national record they had a 280" motor with a 6:17 rear and a 3:00 first gear. (Nash 5 speed). Also had a 50lb. flywheel. Car weighed 3400lbs. Went 11:00 at 126. 1957 chevy 2 door wagon. My theory on the small blocks is start with the gears and a good motor will take care of itself. When I would ride in the 375 hp BB camaros they felt like rockets, but when I would run them with my 69 LT1 nova I was right at their door. Ben Wenzel goes 10.60's with a D/S 302 67 Z/28. My feelings Ken, is that your car was one of the most Super Cars at the reunion. Talk about history! You car is Day-1 and never changed.
Old 01-07-2005, 04:33 AM
Thanks Sam. I've had a lot of help, especially from Dave Libby who told me the set-up that was used on the clutch and flywheel back in 1968. When I weighed the current 40lb Hayes flywheel and clutch set-up, it weighed 64 pounds.
The Wenzel's are quite a dedicated crew, I heard that Ben and Jerry MacNeish got to race each other at Indy last summer. That would have been some race to watch!
Old 01-07-2005, 05:14 AM
Chevy454 Chevy454 is offline
Ben Wenzel
