Old 12-11-2004, 08:01 AM
SuperNovaSS SuperNovaSS is online now
Default Re: 68 SS 396 CAMARO MAYBE A MOTION CAR
That is a 69 396 block as you probably already know. Motion could have upgraded from a 325 or 250 HP to a 375 HP but I would think they would have used an engine theypulled out of one of their SS427 conversion cars. What are the dates on the 840 heads?
Old 12-11-2004, 05:11 PM
l.i.man l.i.man is offline
The car also has power disc brakes on the front. Manual sterring. It has a push button start (Also has the Key) on the dash with guages were the heater controls would be. Above these gages are 2 switches that were drilled into the metal dash. I also noticed that all of the cast flashings on the block & heads have been ground off. It may just be a street - strip car that Motion worked on ? I will pull the tank after the holidays maybe I will get lucky. I will keep digging. You never know.
Old 12-11-2004, 06:35 PM
resto4u resto4u is offline
A 67 ce block according to his numbers. Roger
Old 12-11-2004, 06:41 PM
A replacement block yes.
But I am just curious as to what year exactly,besides the casting date.
The numbers following the "CE" code will dictate that,but there is a letter/number missing there maybe.
l.i.man can you recheck?
Old 12-11-2004, 09:04 PM
Jeff H Jeff H is offline
The heads are dated to go with the car so it might just be a warranty replacement short block and the original heads/intake/carb went back on it. It seems unlikely it's a Baldwin/Motion car due to being built at the VN plant, but it could be a Motion modified car. Sounds like it has some interesting history it's not telling.
Old 12-12-2004, 05:28 PM
Here is the cowl tag #'s. I will double check the suffex #'s on the block. Car is at my mothers in another town. I do plan on droping the tank. Also my book says that a 272 block was made in 68 & 69. The date code on the block is E-16-8. Another thing is where the date code is. I have another 396 short block casting 272 out of a 69 camaro 350 H.P. 4 speed. Suffix T0115JF. The date code is on the pass side bottom near the freeze out plugs. The 375 H.P. motor has it where the trans bolts up. Where the casting # for the engine is. I will double check the suffix on the 375 motor.
06C 0627
ST 68-12437 LOS
TR 722 N-N
Old 12-14-2004, 06:02 AM
Here are some pictures. members.aol.com/manifldman/ss
Old 12-14-2004, 06:08 AM
Pics http://members.aol.com/manifldman/ss1
Old 12-14-2004, 06:09 AM
pics members.aol.com/manifldman/ss2
Old 12-14-2004, 06:10 AM
pics members.aol.com/manifldman/ss3
