Old 12-13-2004, 10:35 AM
GTO_DON GTO_DON is offline
Default Re: LS7 Head Info Needed
The square port heads have 1 small hump in the front identifying as the high horse head.
1969 GTO convert RAM AIR 4spd
1964 GTO convert survivor
Old 12-13-2004, 10:44 AM
mockingbird812's Avatar
Pantera,
I realize that the casting symbol is usually found on SBs, but LS6 heads (291's) from 1970 had characteristic single humps in the casting flash line. The hump I was referring to is at the front of the head (facing the fan). It is a quick (although not conclusive) ID w/o looking inside the valve covers. I found it odd that Colvins does not call out this hump in the description of this head. One had it the other didn't. I just can't figure out why it has it.
Sam
Sam...
Old 12-13-2004, 10:52 AM
I guess I am a bit confused. Colvin's calls the heads I looked at the other night (3994026) as being for a 1971 Chevelle LS6 454/425. But there never was such a beast (at least in production). So if what COPO Anders says "In 1971 the LS-6 was only available in the Corvette. It used aluminum heads." Then what application did the heads I looked at have?
Sam
Sam...
Old 12-13-2004, 08:03 PM
Pantera Pantera is offline
This is what Mor-tec says about the usage of these heads
3946074 69&71 rect OPEN 'Aluminum, ''69 427 L88, ZL1, 118cc chamber & '71 454 LS6, "round exhaust port"
3994026 71 rect OPEN '454 LS6, 118cc chamber
6272990 70-up rect OPEN 454 service replacement, used on some MKIV crate engines, 118cc chamber
I just went out and looked at some heads that I have and after quite a while looking I think I see what you are refering to on the hump. I only have HP heads # 840 # 990 #208 here at the house and they all have the hump. It is about the size of the end of your finger?
I learn something everyday on here. I never noticed these before. I have no oval port heads to compare to.
If someone has a low HP motor check and see if this is different on your heads to see if this is correct?
70 BM Phase III GT Vette
69 BM SS427 GT vette?
69 L78 Nova 7k mi
73 Pantera
69 Vette B/P SCCA
Old 12-14-2004, 07:38 AM
I guess I am a bit dense here. The application of these heads (3994026 '71 rect OPEN '454 LS6, 118cc chamber) are supposed to be for a '71 LS6 CHEVELLE, but there was no such animal. So what,if any, car were they used in?
Sam
Sam...
