Old 02-16-2004, 11:45 PM
Mark_C Mark_C is offline
Default Re: early 69 no x codes
You don't need to get under the car to see the fuel lines, they are attached to the inside of the passenger side frame right next to the engine. Assuming it's an 8 cylinder VIN 2 fuel lines is an LM1, or an L48 if it's a small block, L34, or L35 if it's a big block. Single fuel line could be an LF7, Z28, or L78/L89.
Look at the clutch adjustment rod. Two piece rod with an adjustment nut in the middle of it that is bent 90 degrees where it passes thru the Z-bar is a small block setup. One piece rod that threads into a swivel that in turn fits into the Z bar is a big block setup. (that and the fact that the big block Z rod is 1" longer than a small block rod - of course you have to have a smallblock one to compare to)
Muncie transmission or Saginaw? Look where the speedometer cable goes thru the firewall. If the hole is above the throttle linkage is a Muncie, above the wiring harness connectors is a Saginaw. The hole above the wiring harness is present on all cars, just plugged if a Muncie was installed. Muncie is in SS's and Z28's. Saginaw in everything else.
Count the coils on the hood springs. 26 is a flat hood/ZL2 hood, 28 coils is an SS hood.
Mark C.
My Pace Car
Old 02-16-2004, 11:49 PM
berger berger is offline
very cool, we will attempt to get more info, did early z28s come with such setup as well, guy presumed it was an unorig 350 in it as he thought car was ss350 but no way with those multi's and tach...
67 Rs modified stormer z28 482cu in.yenko camaro
67 327 camaro
69 SS 396 camaro
Old 02-17-2004, 12:10 AM
Check the motor mounts, and take back seat out and see if there is crayon written on the cross brace. May say X3, X33, or the color of the interior. Mine says (DG3). I would say that means Dark Green interior.... X33 (1969 Z/28). Motor mounts on frame should be L=3945507 R=3945508 if it is a Z/28 or SS car. Hope this helps. Sam
Old 02-17-2004, 01:00 AM
THANKS, we'll post what we find out...
67 327 camaro
69 SS 396 camaro
Old 02-18-2004, 05:45 AM
Kurt S Kurt S is offline
6000 yellow line /7000 red line tach orig
???? Never made such an animal in 69.
Kurt S - CRG
