Old 12-22-2003, 07:04 PM
VintageMusclecar's Avatar
Default Re: L72 `69 Camaro NHRA stockers
Thanks for the replies [img]/ubbthreads/images/graemlins/smile.gif[/img]
I was under the impression the 427/425 Camaros ran A or B Stock. Am I correct that they run un-factored at 425 hp?
Re: minimum weights...
Stick car is natural A/Stock at 8.00 lbs per HP. Add 170/driver = 3290 min.
Auto car is natural B/Stock at 8.5 per HP. Plus 170 = 3485
Is this correct? As I'm predominantly a "street car" guy, the whole NHRA factoring thing is a little fuzzy to me, hence the "newbie" questions.
I would like to discuss this further off the board if anyone is willing to share some info. I obviously don't expect anything proprietary, I'd just like to cover some basics to make sure I understand them correctly. If anyone is willing to help, please PM me or shoot me an email (in my profile). Just trying to spare a little board space and bandwidth [img]/ubbthreads/images/graemlins/beers.gif[/img]
You guys rock. [img]/ubbthreads/images/graemlins/worship.gif[/img]
Eric
Old 12-22-2003, 08:22 PM
Chevy454 Chevy454 is offline
Might as well cover this here, in case anyone else is interested. The rest of you class racers jump in and correct me if I lead him astray...
First off, take a look at the NHRA Stock Car Classification Guide. This will provide you with the current HP factor, from which you can figure your minimum weight and your class. I'll use the L-72/400th as our example.
From the link above I select "Chevrolet, 1969", which will open the page for all 1969 Chevrolet combos. Then, I scroll down to "Camaro", to "Coupe w/TH", which is the L-72/auto combo. It tells me it has an "8.06 lb per HP" factor, and is factored at 425hp. Now, with that, I look in my NHRA rule book (thanks Barry!) and it tells me that it falls in "A-stock", which is 8.00-8.49. Now I can figure my minimum weight. Since it's a natural A/S car, I can use the class minimum weight factor of 8.00. Multiply 8.0 by the Hp factor (425), add 170 for driver, and you get a minimum weight of 3570. NHRA also allows you to drop down 1 class by adding weight, which means since it's a natural "A" car it can drop to "B" by adding 212.5 pounds.
See, clear as mud! [img]/ubbthreads/images/graemlins/grin.gif[/img]
Old 12-22-2003, 08:40 PM
You did GOOD GOBER [img]/ubbthreads/images/graemlins/naughty.gif[/img] [img]/ubbthreads/images/graemlins/biggthumpup.gif[/img]
Jake is my grandson!!
Old 12-22-2003, 10:26 PM
larry_csa larry_csa is offline
First I'am sorry for the mistake of misreading L-72. I should not answer the computer at 11.30 at night.
NOW. A 427/425 will make A only in a 1969 camaro. It can not get heavy enough to go to B.
Fast A cars Bobby D.
Bobby Brannon
Thomas Arnett
Joe Sorenson
A 1969 CAMARO will make B with a Stick but will NOT make C with a stick. It will not make weight.
Fast B Stick ED Bendez
Geroge Cottell
A 1969 CAMARO will make A OR B Stick with Alum Heads.
Fast A Stick Kevin Helms
A 1969 CAMARO will make B or C Auto With Steel heads.
It ONLY make B with Alum Heads.
A 1969 CAMARO will make E auto with a 396/350 Motor(parson & Myers)
I do not know anything about weight for Novas or Chevells. the Person asked about A CAMARO. I run Div 2 3 & 4
Thanks Larry 2206 C/SA [img]/ubbthreads/images/graemlins/beers.gif[/img]
Old 12-22-2003, 10:38 PM
Any of you guys ever run into Mike Keenan (sp?) or any of the other Team Checkmate cars? I've talked with them a few times on the phone about some parts and stuff...I *believe* Keenan runs B/S, but I can't remember if it's a Camaro or Nova.
BTW, BigDog needs some 074 heads!!!!
Old 12-22-2003, 10:56 PM
OK left out some things
396/375 A Stick alum Heads
396/375 B Stick steel heads
396/375 Will NOT make C stick
396/375 B auto W/Alum heads 3485
396/375 B auto Steel heads 3485
396/375 C Auto Steel heads ONLY 3680
427/425 A Auto Camaro 3570
A 427/425 in a Chevelle will make B at 3785 (OUCH)
Sorry for all the screw ups. My thought process is not working right lately [img]/ubbthreads/images/graemlins/dunno.gif[/img] [img]/ubbthreads/images/graemlins/beers.gif[/img]
P.S. everything after Joe Sorenen's name is about 396/375
Rob Mike runs a 1969 camaro with a 427/425 or a 396/375 alum . paul runs a 1968 camaro with a 396/375 steel heads. Paul went a 9.98 at a 133 and change. at Montogmery
in November.
Old 12-22-2003, 11:51 PM
Paul Mercurie and Mike Keenan run camaros. They were the guys to beat in the 70's with there modified production camaros. [img]/ubbthreads/images/graemlins/[/img]
Old 12-23-2003, 12:03 AM
Bob Broadbent set the national record at Maple Grove with there 1969 camaro in C/Stick. I think they run a 375 horse 396. Tom Baird went a 10.10 at the Grove this year with the Silver Car in A/Stick (Dutch Classics). Seems that most A/Stick cars are running 396's they seem faster than the 427. A/SA seem to be the 427 cars. I believe Helms is a 396 with aluminum heads, that is why he went to A/S (head change)if I am not mistaken. Gary Hettler likes the 396 motor better with the 4 speed, I was told.
Old 12-23-2003, 01:04 AM
Same cam same carb same heads lot of differance in weight [img]/ubbthreads/images/graemlins/beers.gif[/img] Broadbent record holder for years [img]/ubbthreads/images/graemlins/worship.gif[/img]
Old 12-23-2003, 01:20 AM
Bob used to be in E/S with a 302. Dave LeBrun built the big motor as with Ed Bednaz and gang. LeBrun runs C/SA with a 69 camaro 375 hp.
