Old 11-10-2003, 11:28 PM
Default Re: 1967 Z-28 Parts Wanted
I believe they did Joe. Sam
Old 11-11-2003, 12:03 AM
rafbody rafbody is offline
I have not checked the 283 cranks I have but if it is a 302 crank, I am pretty sure it was tapped. The 302 had an 8inch harmonic balencer where the 283 had a much smaller one.
Russ
Russ
Old 11-13-2003, 01:30 AM
RPZ28 RPZ28 is offline
Sam, it would be impossible to wear the tuffriding surface off. The nitriding process is about .015 thousands deep. The crank would have to be .030 under to be completly gone.
Zedder I have a 67 z28 crank #3815822 std.- std. for $400.
let me know if you are interested.
Ron
Old 11-13-2003, 03:07 AM
Zedder's Avatar
Zedder Zedder is offline
Thanks Ron, but I just bought one from another forum member.
Mark
Old 11-13-2003, 11:46 AM
Ron, I have 2-1969 302 cranks. One is 20/20 and the other is standard. I guess the one that is standard still has the tuffride, and the other one 20/20 is gone? How can you tell? Thanks, Sam
Old 11-14-2003, 12:51 AM
Sam, the only way to tell is to do a rockwell"C" hardness test on it, but the diamond tip from the tester will leave a small prick mark on the journal. The only problem with nitriding is that it is the hardest at the surface, the more you grind off the softer it gets. Yours at .020 under still should have some hardness left, at .030 under its usually complety gone. I hope this helps.
Ron
Old 11-14-2003, 03:59 PM
Thanks Ron. I thought that the hardness was only about .015 thick at the most,but You learn something new everyday! [img]/ubbthreads/images/graemlins/biggthumpup.gif[/img]
Old 11-15-2003, 12:35 AM
Sam, the .015 depth is radial, and .030 is total depth on the diameter.
Ron
Old 11-15-2003, 12:46 AM
Thanks for your help Ron. Sam [img]/ubbthreads/images/graemlins/biggthumpup.gif[/img]
Old 11-25-2003, 10:16 AM
TDW TDW is offline
Mark...There is an ad on Team Camaro this morning you may be interested in. Guy thinks he has a 67 Z28 block and crank. His name is Don. 509-276-6090.
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
