Old 08-08-2003, 03:42 PM
Default Re: WANTED: 67 Camaro M21 Tranny
Denis, I don't understand what caused the breakage - the clutch etc.. is still there, so was it the tailshaft that broke and twisted everything apart?
Makes me want to install my Indian loop b4 I go to the strip!
Old 08-08-2003, 09:10 PM
PxTx's Avatar
PxTx PxTx is offline
I'm guessing there was too much play in the tail of the trans. Either the output shaft was fatigued or the bushing was worn too much? Anyone else have thoughts on this kind of Muncie failureÖ
Paul T
Paul III
Old 08-08-2003, 09:47 PM
T Billigen T Billigen is offline
Do you guys use a scatter shield when you run your cars at the reunion? Very dangerous to run a solid lifter chevy without one! [img]/ubbthreads/images/graemlins/scholar.gif[/img]
1968 COPO/YENKO 9737 Non-Converted
Old 08-08-2003, 10:19 PM
JoeC JoeC is offline
It appears that something caused the trans to lock solid then the momentum of the spinning wheels, rear end, drive shaft, and Dyno caused the output shaft to shear in half and shatter the bell and trans housing. It is difficult to say without a close look at all the parts.
Old 08-08-2003, 10:33 PM
Denis Denis is offline
Just got back from the trans shop with the car, and a box of bits.
Appears to have been caused by the U-joint coming apart, a worn tail shaft, or both. Everything else came about as a consequence of the above. Pretty friggin' dramatic. None of the guts are worth reusing, gears look pretty worn already and not worth salvaging. Only piece that survived is the side cover and the shifter--finally, a good reason to mount the shifter on the crossmember.
Mr Maynard has most of what I need to replace the trans and bellhousing, need to follow up with him for the main case after he's had a chance to check his stash. Driveshaft will need to be trued and balanced, floor will need some mending, engine needs to come out to reweld on a broken bellhousing mounting boss (I found the broken piece).
Whew, what a day! Nothing another $5-6K won't fix.
Old 08-09-2003, 12:58 AM
crash crash is offline
Denis, I've got a P7E05 main case without a VIN or I have four 010 cases without any VIN or build dates...Hope this helps...Crash
Old 08-09-2003, 01:35 AM
VERY INTERESTED in the P7E05/NOVIN main case! PM me w/ phone # pls.
Old 08-09-2003, 02:17 AM
Denis, E-mail me for phone # [email protected] Crash
Old 08-09-2003, 04:50 AM
hvychev hvychev is offline
Dennis was this the original trans?
Frank Magallon
Old 08-09-2003, 05:48 AM
Busted trans had 'correct' dates and castings but no VIN. Not original to the car.
