Old 11-27-2002, 05:19 PM
Default Re: Pure Stock Drag Racing tips & tricks
I was referring to the Comp cam he has in his red Deuce.
The Comp Cam that Neal had in his '68 BB was a little cam he had put in for the street many years ago, he didn't have a local source of higher octane fuel. He knew it was much smaller than stock, but thought it would work better with the iron mani's. He was indeed happier when he put the L78 cam in, so was the BB [img]/ubbthreads/images/icons/grin.gif[/img]
I wouldn't try matching you guys beer for beer! You must admit, JJ is awfully funny when he gets a few in him though. Quite animated when he shows you how to shift the 4hitter in the middle of the hotel room, then he burned himself with his cig!
Old 11-27-2002, 09:44 PM
Marlin, I am new to the site, but I met you at the Vargo Dragway Reunion 2 years ago. Your car is great. I love the overspray on the cowl panel. In 1971, we put a 1970 LT1 crated motor in my 1969 SS Nova. I bought the motor from chevy, and we took it apart and went over everything and had it balanced and clearanced. It had a stock LT1 intake, and the stock 1970 LT1 chevy cam, I think we set it at 24 and 26!!?? The car had the original 4:10 ring and pinion, and the original re-jetted 780 holley and went 12.56 at 108 mph. I still have the time cards. The stock single point ignition was also good enough. The 780 was from a 1969 Z/28. I changed the M21 trans and put my spare M20 trans. in and immediatly picked up 2 tenths. 90/10 shocks in the front and 50/50 in the back. The stock cam was a bear. Once it hit 3000rpm it pulled to 6500 instantly. I had 7 inch tires in those days 28 inches tall, and open headers. Everything is about the right combination. I bought the car new from Mullin Chevrolet in Ambler Pa. in April of 69. Cloth bench seat 4 speed, no gauges. Dark Blue, lite blue interior. A good guy to help you out on your tune up is a few miles from you. (Pete Suriano) Pete's Automotive Pottstown. (610)326-8322 Good Luck! Sam
Old 11-27-2002, 09:48 PM
Chevy454 Chevy454 is offline
Now we are getting somewhere! Great info, Sam! What was the Nova's "average" 60 foot time with the 12.56 setup? What exhaust were you running?
Old 11-27-2002, 09:52 PM
Oh my! Do you have ESP or something??
I was just talking about you to a neighbor, and was trying to remember what shop you told me about in Pottstown. I will be needing some machine work done in the near future, small world.
I totally believe you went the 12.xx numbers with that combination, also the 2 tenths from the M20. My buddy Neal and I have compared the slips from an M20 vs. M21, the M20 60 foots better and the M21 does better at each marker after that I think. But the M20 does such a number on the M21 in the first 60 feet, you run out of track before you can catch him.
Hope to make it back to the Vargo show next year. Stop by the shop sometime in Perkasie, behind the daycare on 5th street. My new project is in there, '69 rallye green, L78, 4sp, 3.55 12 bolt, custom interior w/ buckets. It will be at Vargo in a few years [img]/ubbthreads/images/icons/smile.gif[/img]
Old 11-28-2002, 01:54 AM
Rob, In the old days, I don't remember Maple Grove Dragway with 60 ft. timers back then. I forgot to mention I had Lakewood traction bars. Really the key to everything is the right combination. I had a set of Casler headers, and I made a set of 6 inch collectors and bolted them on. I truly think to this day with a set of 488's I could of put this car in the 11's. The car weighed 3250lbs to run small brute eliminator. Nothing trick, just a real good hone job on the cylinders, and good basic head work.
Old 11-28-2002, 02:17 AM
Marlin, Pete is a great guy. Has been around for many years. Has done all my work since 1970. I finally did a real good motor for my Nova about 1974. We used stock LT1 pistons and moved the ring land up and put an 1/8in. ring up top. We put an old engle roller cam, with about 500inch lift, put 88's in the rear and took the back seat out and went 11.58 at 122 down Cecil County. That car was unbelievable. The MPH was high, because I should of had 538's in it. Basically stock pistons,the first guy in this area to use the angle plug heads. I think they were the 292's, bought them from Shaws Speed Shop. Pete did the heads and cut them for the big springs. I have some old pictures of the car at Maple Grove, I have to see if my kid can down load them for me. I live in Souderton, so I am not far at all from Perkasie. None of this is rocket science, just basic! Do you know that guy in Greenlane with the orange Yenko, original paint etc. He bought it in about 1970, coming out of Nam. He told me he paid $2700 for it. It is a very, very nice original car. Says it is original motor. I don't know. Sam
Old 01-02-2003, 09:16 PM
Pete/Rob;
What type of driveshaft safety loop do you guys use, did you have to drill holes in the floor pans?
Also, how did you attach a radiator overflow container?
PXTX;
I'm still mulling over your email, good explanation, thanks for the info.
Old 01-02-2003, 09:27 PM
Sam;
Been to Dave's house several times, once with BKH, his orange Yenko camaro is a very nice car. He has several large pic's of him racing it at the grove. Nice car, even has a few options, guages, v/t, and p/s.
Old 01-02-2003, 09:28 PM
I'm running an Indian Performance(?) unit, that bolts to the trans mount, but will make the other ones from here on out. I'll try and dig out a picture, as it's a pretty nice setup. If Casey sees this, he improved his, and I know HE has pics. Casey? As for overflow, I just ran a hose to the washer bottle. Pete?
Old 01-02-2003, 09:36 PM
Marlin, I talked to him a couple of times at the Wal Mart show. He is a nice guy. Nice car pretty much unrestored. Let me know when you are going to be in Perkasie, I'll stop around. If you are planning on running your car, you may need a blow proof bellhousing at Maple Grove. You have a solid lifter motor. Sam
