Old 08-30-2002, 03:36 PM
Stefano Stefano is offline
Default 1966 L79 Nova
Marlin,
I need some Nova Help. There was a 1966 Nova SS for sale at a recent cruise night.
He said that it originally came equiped with a 327 factory Holley Carb and aluminum intake, Muncie 4 speed and 12 bolt posi.
The original block and heads were scrapped and all that remains is the original trans, rear end ,the correct intake carb and original curved correct thermostat housing.
What other clues would help determine if it was a true high HP solid lifter Nova? Was the 12 bolt available in all 327 applications for 1966?
Old 08-30-2002, 03:46 PM
Default Re: 1966 L79 Nova
Stefano;
The '66 L79 Nova is a hydraulic lifter engine.
Unless there is paperwork, or the original block, I don't think you can verify that the car was an L79 Nova. To my knowledge there is nothing in the VIN or Trim Tag that denotes RPO L79. The 12 bolt rear was also available with the 327/275hp engine, all were mono-leaf setups since the multi-leafs did not arrive until '68. The curved neck thermo housing is not a hard part to find, and may not be original to that particular car, same with the intake. If it's a hardtop, then it should be a SS and have the brackets on the tunnel for the console. I have not seen any SS L79 Novas without the console, although I'm sure some were made.
If you're thinking about buying it, make sure the back cove panel is super nice - because they are super expensive!
Old 08-30-2002, 04:06 PM
Marlin,
Was there a solid lifter option available?
He wasn't representing the car as a high horse, its just that the equipment and story Jive upon initial inspection.
You know ,tossed out the original 327 and kept the original carb and intake.
The thermo housing is available in repro, but the car was not done to fool anyone IMO.
Yes, it is also an orig. buckets and Console car.
Is the carb linkage specific to the Holley equiped Novas?
Old 08-30-2002, 06:26 PM
TimG TimG is offline
The solid lifter version was rated at 365 horse and was only available in the Corvette in 64 and 65. No solid lifter small blocks in the Chevrolet lineup in 66. Look at
the tach for 6000 red line.
Old 08-30-2002, 06:30 PM
Tim;
I'm not sure the Nova's received a tach, other than the 'lazy susan' style that was an accessory item - which had an adjustable redline of course.
Stefano;
The carb linkage is the lever type I believe, so it probably won't look any different than the Rochester equiped 275hp cars.
Old 08-30-2002, 07:05 PM
Thanks, don't know much about these Novas but sure do like the engine.
Old 09-01-2002, 05:16 PM
William William is offline
This thread leaves the impression that only an SS could have the L79 engine.
The L79 option was available on all '66 Novas. Even a few wagons have turned up.
Old 09-16-2002, 02:52 PM
Even 4door's?
[img]/ubbthreads/images/icons/grin.gif[/img]
Never say never, Don Fezell has a '63 Chevy 409/409, 3 on the tree, 4door!
Old 09-16-2002, 10:51 PM
T Billigen T Billigen is offline
Marlin,
The car that Don Has is a 62 four door three on the tree 409/409. I remember that car when I was in high school, the fellow that owned it lived two miles from me! Neat car, has all the paperwork. I had a chance to buy it, but I snoozed and Don Did'nt.
1968 COPO/YENKO 9737 Non-Converted
