Old 03-15-2002, 01:31 AM
jon rand jon rand is offline
Default Re: Another Resto Question -- Bell Housing
Paint dosen't Stick to aluminum to well, a couple good blast at the car wash will blow it right off.
Old 03-15-2002, 05:42 AM
69L89396 69L89396 is offline
When was the transmission attached to the bell housing? It seams if the engine left the factory with the transmission, it should have some overspray on it as well if it was painted with it attached?
I'm like you Kirt S, I have not seen any bellhousings with paint and they didn't look blasted. I have had some before that were painted back in the old hot rod days.
How do you make paint stick to aluminum anyway without special primer?
[Edited by 69L89396 (03-14-2002 at 11:42 PM).]
Old 03-15-2002, 06:19 AM
I've had a a few bellhousings that I had to really work at to get the orig. paint off of. At least I assume it was orig. paint.
Old 03-15-2002, 06:26 AM
L89DRMR L89DRMR is offline
I parted out an L78 with 48,000 miles on it and the bellhousing was completely covered in orange paint. This car was purchased from the original owner who never raced or modified the car so at least this one came through with the painted bellhousing,since he never removed the drivetrain or replaced the clutch when he owned it. Dave
Old 03-16-2002, 05:59 PM
I was talking to a friend that restores cars and he said that most of the big block solid lifter Camaros he has seen, did not have the bell housing painted. He did say that on all the Corvettes they were though. The Camaro Z/28's were painted also. But there are too many inconsistencies to say which is correct. Back them there were no standards to go by like there are now.
So I guess it can go either way and be considered "correct".
Old 07-03-2002, 09:48 PM
I'm checking back through some of the old topics that I've missed.
Us Deuce guys have had this debate for a long time, and we were fortunate enough to get some pics of Dave Belk's bellhousing just as they were pulling it out of the car. It appears that his car had a wide band of orange at the flange. I think Schoneye's had quite a bit more orange on his bell. We concluded that for the Deuces, which were built in three consectutive weeks, the bell should not be completely orange but have a several inches of the flange oversprayed.
If some new info shows up later, at least it's not a tough thing to change! [img]/ubbthreads/images/icons/grin.gif[/img]
Old 07-03-2002, 09:56 PM
I am documenting a very low mileage untouched survivor car tonight, checking numbers, dates and authenticity. It is a 4-speed big block car which has had NO work done to it. I will make note of the bellhousing paint and let you know what I find. This is a Tonowanda engine plant car.
Old 07-04-2002, 12:09 AM
T Billigen T Billigen is offline
I ownd a 1967 impala with 1,450 miles never touched, had the 327 from tonawanda and the bell housing was completely painted. Bottom side of car was painted Marina Blue just like the rest of the car.
1968 COPO/YENKO 9737 Non-Converted
Old 07-04-2002, 02:19 PM
Looked at the car last night. The upper half of the bellhousing was painted 'almost' completely. About 1/2 down the bellhousing, it tapered back to a 4" band around the bottom. I will confess, this is the only one I had seen like that. They have always been completely painted or just a band around the flange in the past.
Old 07-04-2002, 06:52 PM
I'm sure every person doing the painting had their own way of doing things, so I don't think you can say anyway is right or wrong! On my low mileage Impala the fire wall was not painted black, it was also Marina blue. I talked to some people that worked at the Lordstown plant in Ohio that worked there in the 60s, they told me if someone had to leave the line for some reason and could not get a replacement, cars would go down the line missing parts and people painting firewallls and other areas missed cars. Thats probably what happened to my Impala. I just can't see how anyone can say what is right or wrong. Just a lot of speculation!
