Old 12-11-2025, 11:18 AM
Mike L78 Mike L78 is offline
Default Casting date
I will look for the date code and add pictures later today
Thanks All for your help
Old 12-11-2025, 12:55 PM
Default Casting #
The rear has a casting # 3894860N does this indicate a posi ?
Old 12-11-2025, 01:08 PM
Too Many Projects's Avatar
No, a posi code would be included with the assembly code with an E as you have in the first pic.
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
Old 12-11-2025, 01:10 PM
Post 12 Bolt...
That is the casting number for the 12 bolt center section....68-69 Nova and Camaro
The posi designation is in the stamp on the tube...there will be an E below the gear ratio and date. the E stands for Eaton Posi...of course, you should always look inside to confirm what is in there.
Old 12-11-2025, 01:15 PM
Post 12 bolt...
Mike...
One more thing...should have clarified...the BT code actually designates the posi from the factory...the E indicates the supplier of the unit. If you look at Colvin's book you will see a listing for all the possible codes and applications.
Tom
The Following User Says Thank You to WILMASBOYL78 For This Useful Post:
big gear head (12-11-2025)
  #16
Old 12-12-2025, 11:01 AM
Default 12 bolt pictures
dding a couple pictures of the 12 bolt think I have the date but it’s hard to read.Also getting the leaf springs and traction bars .$1700 . What do you think
Old 12-12-2025, 01:59 PM
iluv69s iluv69s is offline
Looks like 09(?)- 24-8 for the cast date and 09-27 for assembly date. ( Thought cast date should have letter for month ).
Great for an early car ! $1700 is a great deal if it’s a working complete rear . Jmho
Old 12-12-2025, 02:29 PM
Seller needs to be willing to pull the rear cover so you can see what is actually in there.... assembly build codes guarantee nothing after all these years and with a non original cover, there could anything, including trashed components, in there.
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
Old 12-15-2025, 12:57 PM
Default 13 bolt
I picked up the 12 bolt it’s in nice shape not all pitted up . The casting date is I so it goes along with the September BT stamp.Thanks for the help
I am looking at Lakewood traction bars the kind with J Bolts and they extend in back with another clamp.I am trying to verify they are Camaro/nova . I will post some pictures.
Can anyone tell me anything about the leaf springs pictured? 5 leaf? GM or aftermarket?
Old 12-15-2025, 04:43 PM
Default Traction bars
Any info on the traction bars?Will they fit 69 nova
