Old 10-24-2025, 06:50 PM
Pat C Pat  C is offline
Here’s the stamp from the L78 on BAT.
Old 10-24-2025, 09:44 PM
----That's the nicest trim tag I have ever seen!....Bill S
Old 10-24-2025, 10:22 PM
vette5762 vette5762 is offline
Richard trim tag 4L and a color change and 06C ?
67 RS/SS L-78 Convertible
62 Bubble Top 409-409
66 SS Nova L-79
Old 10-24-2025, 10:32 PM
Steve Shauger's Avatar
Administrator
Not typical engine stamp. The rear is coded QL which decodes to 331 non posi and trans stamp should start with P = Muncie 7 = year or P7 which it doesn't, and no claims of originality of drivetrain.
www.vintagecertification.com
Pat C (10-25-2025)
  #15
Old 10-24-2025, 11:20 PM
luzl78 luzl78 is offline
Originally Posted by 1967 4K View Post
My car is 06A built Norwood. Block is a 406. Never had it looked at by someone like JMc. It is what it is, had a few 69 dated parts on it when i bought it and still does. I enjoy it.
Couple of pad pics n TT.
Isn’t that a z28 code? 4L
Old 10-24-2025, 11:32 PM
1967 4K's Avatar
1967 4K 1967 4K is offline
Ooops wrong TT, not the 4K car. My bad.
Richard
1967 Camaro SS 396/375 4K
Old 10-24-2025, 11:48 PM
1967 4K's Avatar
LOL 😆, I,m messing with you guys showing the 4L TT. Was wondering who’d be the first to notice it. Check out the color of the 4L TT. Very cool 😎.
Richard
Old 10-25-2025, 12:35 PM
Any thoughts on the trim tag ? Should a 07B car have a 406 or a 323 block ?
66 SS Nova L-79
Old 10-25-2025, 06:01 PM
Administrator
It's ironic you ask that question because in 1996, I had to prove my 323 block came in late production 67 L78 Camaros. The conventional wisdom at the time was skeptical about the usage. This is a 1994 version of By The Numbers in later versions this was updated to confirm the usage. Back to your question you need data points to prove your question. I know of 3 7B built cars with 323 blocks.
In addition heads 840 were used in late production such as my car and the temp sender boss was not drilled or tapped since the sender was not mounted in the head until 1968.
Old 10-25-2025, 06:58 PM
1967 4K's Avatar
The bid is at $51,500 with 4 days to go.
Richard
