Old 08-17-2025, 03:11 AM
lpar1969 lpar1969 is offline
Yenko Premier Member
Originally Posted by KevinW View Post
So, I can't see the wire colors in the rectangular connector the way you took that pic, we will wait for the new pic. Here is a post on Team Camaro showing the gauge wiring diagram:https://www.camaros.net/threads/wiri...gauges.467971/
Also the pic with the purple wire connector is for the clutch safety switch mounted on the pedal support.
Kevin, thank you. I just uploaded 2 more photos
Old 08-17-2025, 12:58 PM
KevinW KevinW is offline
OK, the number of pins match mine, but I am not seeing the red common wire in position C or the brown wire in position F. Do I see cut wires there?
Here is a pic of mine:
69 327 convertible (driver)
Old 08-17-2025, 04:39 PM
I do see some wires were cut under the dash. I will have to trace them back.
Would that mean the car was console with gauges?
Lou
Old 08-17-2025, 06:04 PM
its looking likely. Does the car have a tach in the dash? And clock in the center over the steering column? They were part of the gauge package with a console.
Old 08-17-2025, 06:52 PM
Strange thing is I have tachometer but gas gauge in the middle. Not sure if the gas gauge is original in the middle
Old 08-17-2025, 09:56 PM
Gas gauge in the center was a separate gauge package when a console was NOT ordered. The console connector would not have been there at all with that order. Someone changed something!
You need to trace the gas gauge wiring to see if looks factory or has been messed with.
Old 08-17-2025, 10:06 PM
Kevin
I’ll get under the dash and start tracing the lines. I have the Classic Wiring diagram which I just got
Old 08-18-2025, 03:17 AM
169indy's Avatar
169indy 169indy is offline
Default Console WIring COnnector Data
Here we go:
Data
69 Los Z11
68 SS/RS 396/325
68 Los Z28
The Following 2 Users Say Thank You to 169indy For This Useful Post:
lpar1969 (08-19-2025), olredalert (08-18-2025)
  #19
Old 08-18-2025, 06:59 AM
Kurt S Kurt S is offline
That's not correct.
U16 was the tach-only option. The gas gauge was in the center. The console was optional. I've seen many cars with a console and U16.
U17 was tach and gauges. Tach and clock in the cluster, gauges on the console. Console was required.
Agreed, something has been changed here.
Kurt S - CRG
The Following 3 Users Say Thank You to Kurt S For This Useful Post:
lpar1969 (08-19-2025), mhm1966 (08-18-2025), olredalert (08-18-2025)
  #20
Old 08-18-2025, 01:29 PM
Kurt, Thanks for keeping me honest.
