Old 03-10-2025, 12:39 PM
big gear head's Avatar
I didn't even know you could get a Silverado with a 4 cylinder. My 5.3 warms up well.
Freddie
Old 03-10-2025, 12:44 PM
69Z11Pacer396 69Z11Pacer396 is offline
What year out of curiosity Ralph? Have a 1994 5.7 silverado I picked up for my daughter and heat is intense..
Old 03-10-2025, 01:27 PM
Too Many Projects's Avatar
4 cylinder turbo became the base engine a few years ago. And with the reviews I've read about the poor mileage, I have no idea how it meets EPA regs, or helps the overall average of the division.
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
big gear head (03-10-2025)
  #14
Old 03-10-2025, 06:10 PM
Ralph Spears's Avatar
Ralph Spears Ralph Spears is offline
2024 Silverado regular cab
Old 03-10-2025, 06:13 PM
All my driving is within 3 miles of home at 20-30 mph below freezing temperatures it takes an hour to reach operating temp.
Old 03-10-2025, 06:19 PM
The only issue I ever had with a Silverado heater was on my 2000. I bought it 5 years old and the second winter I had it, it did not blow very warm, even though the temp gauge was at 210. I started reading about this online and people claimed the core plugged with crap from assembly. They, also, complained about the cost to get it replaced and the DIYers said it was a huge job.
As a former mechanic I had run into this years ago with certain models of cars with a heat hose shut off valve and all we did was back flush the hoses, valve and core, so that is what I did and it heated like a boiler after that and never gave another hint of cooling down from debris.
I know this is not the same as your engine not warming up. Maybe you could do an experiment with a piece of cardboard covering about half of the radiator and see if it heats up better. It could be a malfunctioning thermostat that is stuck partway open or opens too early. Have you talked to the dealer about this and is it still under warranty ?
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
PeteLeathersac (03-11-2025)
  #17
Old 03-10-2025, 08:44 PM
I have owned 6 new Silverado's 4 --- 6 & 8 cylinder and they will not get up to temperature within 3 miles from home in the cold weather where i do all my driving. If i shut the heater fan off and dial the temperature control knob to cold, it will reach operating temp of 207 but when i turn the heater on and put the fan up to high you can watch the temp gauge go down to 180 this is all city driving below 30 mph
Old 03-10-2025, 09:10 PM
Derek69SS Derek69SS is offline
I've never had one take more than about 5 minutes to warm up.
2000 with 5.3, 2011 with 6.2, and 2024 with 6.6 all warm up pretty quick, and all have pumped out a LOT of heat once warmed up.
Old 03-10-2025, 10:33 PM
As I suggested above, go old school and block off half of the radiator with cardboard. Be better than being cold.
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
Old 03-10-2025, 11:15 PM
67since67's Avatar
Originally Posted by Ralph Spears View Post
And by the way it only gets 10 mpg 4 cylinder 2024 (regular cab) 4 wheel drive Silverado all city driving
10 mpg, Yikes!! My 1500 Baby Max never gets below 20 mpg under any conditions.
FWIW Last month I was running around town at below zero and heat was toasty warm with negligible change on the temp gauge. No grille cover.
