Old 07-09-2024, 02:13 AM
396 SS/RS's Avatar
396 SS/RS 396 SS/RS is offline
Originally Posted by Rsconv68 View Post
IIRC, all 12 bolt rear axles were not automatically a posi traction.
That is correct.
Good Judgement comes from Experience. Some Experience comes from Bad Judgement" Albert Einstein
Old 07-09-2024, 11:54 AM
big gear head's Avatar
Draining the old, used oil, is the strongest and worst, smell and there is no way to avoid getting that smell in a building, unless it is drained outside. The new oil, almost, smells good, compared to the old "stuff"...
When I had my rear end shop I smelled like that every day for 15 years.
Freddie
The Following 4 Users Say Thank You to big gear head For This Useful Post:
396 SS/RS (07-09-2024), Arrowsmith (08-19-2024), bcmiller (07-11-2024), scuncio (08-19-2024)
  #13
Old 08-19-2024, 10:29 PM
BJCHEV396's Avatar
Originally Posted by BJCHEV396 View Post
Hi guys,I've never changed the oil in the 12 bolt of my Camino.Would 2 quarts of 80w90 and a 4 oz.bottle of posi additive be enough?Thanks,Bill.
And to seal it up...use just a quality gasket with or without silicone?
Old 08-19-2024, 11:07 PM
Too Many Projects's Avatar
I don't use silicone with a gasket...just lets the gasket slip out of place as you tighten the bolts.
And, yes, a good gasket alone.
Both surfaces white towel clean with acetone and dry.
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
Old 08-20-2024, 11:58 AM
I put a film of RTV on both sides of the gasket. You will hear 20 different ways of doing it. Some people have completely quit using gaskets, but that didn't work out too well for me.
Freddie
Too Many Projects (08-20-2024)
  #16
Old 08-20-2024, 12:16 PM
THAT is the key, a barely visible film, but too many people gob it on and create leaks.
When I use RTV, the only one I use is Ultra Black gasket maker, and Freddie's extensive experience is right, applied correctly, it is helpful. Next step for me, is, it needs to "cure" for 24 hours before I will introduce any fluids too.
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
L78_Nova (08-20-2024)
  #17
Old 08-20-2024, 12:45 PM
Zman1969 Zman1969 is offline
YES!
69 RS/Z 302 VE3 Daytona
69 Chevelle SS 396 375
69 T/A clone LS6/6 speed
90 Formula 350
Old 08-20-2024, 01:09 PM
I have more often than not had leaks in my 12 bolt cover, with or without gasket, with or without black RTV. That is until I started using Permatex's 81182 Gear Oil gasket maker. I still use the gasket but put a thin layer of this on both sides and have not had a leak since. Like others have stated, give it overnight to set and you will have no issues.
The Following 5 Users Say Thank You to SS427 For This Useful Post:
67since67 (08-20-2024), 69M22Z (08-22-2024), big gear head (08-20-2024), L78_Nova (08-20-2024), Too Many Projects (08-20-2024)
  #19
Old 08-20-2024, 05:50 PM
I have never seen that product, Rick...
I'll be getting a tube of that to have on hand.
Thanks !
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
Old 08-22-2024, 05:43 PM
BJCHEV396's Avatar
Thanks for all the tips and info!
