Old 10-04-2023, 03:31 PM
Once you guys have your brake Master cylinders or wheel cylinders rebuilt,are you using DOT 3,DOT 4,DOT 5 or DOT 5.1 fluid?
And what does White Post recommend for either one of those re-sleeved as well?
Thanks.
Old 10-04-2023, 03:34 PM
Steve Shauger's Avatar
Administrator
Originally Posted by Jonesy View Post
Yes Mike Gibbons is awesome!! A guy that actually enjoys what he does!!
Yes Mike is the go-to guy for all my brake needs. His attention to detail is top notch, from restored to survivor assemblies.
www.vintagecertification.com
Old 10-04-2023, 04:06 PM
X66 714's Avatar
X66 714 X66 714 is online now
Thanks.
Dot 4 is recommended by Mike Gibbons. He says the new style seals don't like Dot 5. He also uses stainless steel instead of brass. The brass is too soft & can scratch easy...Joe
Old 10-04-2023, 04:56 PM
Once you guys have your brake Master cylinders or wheel cylinders rebuilt, are you using DOT 3,DOT 4,DOT 5 or DOT 5.1 fluid?
Thanks.
*White Post states: We fully guarantee all parts that are sleeved and/or rebuilt by us, with the exception of those used in conjunction with silicone fluid (DOT 5).
*Lone Star Caliper states: DOT 3 or DOT 4 Brake Fluids are compatible with their calipers, but they do NOT recommend DOT 5 as well and will VOID the warranty on any Calipers.
I have used both for over 30 years and only had (1) master cylinder fail internally and that was on the 1979 Trans Am I just sold. Billy at White Post turned it around at no charge in 4 days, Top Notch! You can't go wrong with either Company Bill
Old 10-04-2023, 08:11 PM
Zman1969 Zman1969 is offline
I second White post BUT - a FYI -if you do booster at same time its a package deal, if you send booster in couple months later its couple hundred more. Ive had master restored and master that was sleeved W/O exterior restoration
69 RS/Z 302 VE3 Daytona
69 Chevelle SS 396 375
69 T/A clone LS6/6 speed
90 Formula 350
Old 10-05-2023, 10:23 PM
Rick i use Dot 3 fluid and that's what White Post said to use.
Old 10-06-2023, 01:07 PM
I had a real poor experience with White Post after using them for years. Wouldn’t go back. A master was incorrectly rebuilt and a caliper leaked both right after rebuild. I asked them to ship UPS they tried to save a buck and send USPS. Parts got lost for weeks and they wanted nothing to do with it.
The Following User Says Thank You to 72-SS-L48 For This Useful Post:
69M22Z (10-06-2023)
  #18
Old 10-06-2023, 01:45 PM
Administrator
I'm not sure what has changed but have used synthetic fluid in various cars since 1978 without issue. I have a car which has silicone fluid since 2001 and zero leakage/issues.
I've heard stainless steel sleeves and the new seals are the issue. I believe most if not all rebuilders will not warranty due to leakage issues.
Old 10-06-2023, 10:22 PM
67since67's Avatar
IIRC (been a while) the chemical make up of silicone fluid changed a while back causing a reaction to the (old and new) seals used in our old cars.
Maybe someone here has more definitive info on this?? - Bill W
Old 10-07-2023, 09:44 AM
Woj's Avatar
Woj Woj is offline
I just had a MC rebuilt by WP for my 74 Ventura and it took almost 2 months. We had some communication issues too. I just about gave up when it showed up in the mail yesterday. I'll see if it works today. I've had several done in the past by them with quality work and decent turn times.
