Old 07-10-2023, 06:13 PM
John Brown's Avatar
You were talking about cast pulleys? I was talking about the stamped steel ones cracking. Sorry if I misled you.
John Brown
Old 07-10-2023, 06:29 PM
Too Many Projects's Avatar
Yes, the part number I posted is for 1967-68 3 groove cast pulleys used with short water pump configuration. As far as I can come up with from research, they will work for 1965-66 also, but not correct part number.
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
Old 07-10-2023, 06:54 PM
big gear head's Avatar
I didn't know you were talking about a cast pulley. Maybe you could use a billet aluminum pulley and paint it cast iron gray. Mine is stamped steel. I have access to lots of CNC equipment so I might make a plate to go inside mine.
Freddie
Old 07-10-2023, 08:07 PM
That would be cool to reinforce yours.
I found a billet pulley on-line last night in Black, but it doesn't seem to exist anymore. I should call the manufacturer and ask.
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
Old 07-13-2023, 02:03 AM
Well you all scared me enough to do something about it.
Freddie
The Following 4 Users Say Thank You to big gear head For This Useful Post:
69M22Z (07-19-2023), John Brown (07-13-2023), scuncio (07-13-2023), Too Many Projects (07-13-2023)
  #16
Old 07-13-2023, 02:10 AM
Very nice, Freddie. Maybe you can market that...
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
Old 07-13-2023, 04:00 AM
the427king's Avatar
Save your dust up and get an oem one....the gm pieces are not much more than the repo unlike the 291ab
No Fisher priced toys here
Old 07-19-2023, 10:59 PM
3869978 is the correct original part number for all 65 Z16's (which all had PS), for all 66 L78's (regardless of whether the car had PS or not - if the car doesn't have PS then the third groove is just empty - don't ask me why they didn't use a 2-groove pulley), and for 67 L78's with PS.
Jeff Helms
65 Z16 Survivor
65 Z16 drag car
66 Chevelle L78 unrestored
67 Chevelle L78 unrestored
67 Camaro SS350 Survivor
Old 07-20-2023, 12:09 AM
UPH879 UPH879 is offline
Had exactly the same situation. Can't understand the disclaimer considering the original application is for 425 and 450hp cars, although looking the other posts seems to answer that question. I ended up getting the same pulley from Heartbeat.....without the disclaimer. There appears to be Chinesium and American made versions available but identical in appearance. I do have an original but it looks like it has been repaired as per the descriptions above regarding durability, so I opted not to use it.
Sounds like there is an opportunity for someone to offer a more suitable product.
In the meantime, won't be revving my 427 L72 to 7K rpm
Old 07-28-2023, 01:42 PM
I see I never followed up on this. I did call the manufacturer/distributor and the grooves are standard depth, so mostly a stock replacement, or dress up part.
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
