Old 03-30-2023, 07:47 PM
cook_dw's Avatar
cook_dw cook_dw is offline
I emailed Muskegon Brakes as I too need my calipers sleeved . White post quoted over $300 a caliper last year hence why I waited. Muskegon quoted cost of Camaro caliper build to be:
$179.95 per caliper with o-ring seals
or
$129.95 if they use lip seals. Turnaround time is approx 4 weeks.
That's bore, sleeve and test pressures. Survivor style no restoration (paint etc)
"Payment will be collected when they're done and ready to come back to you."
The Following User Says Thank You to cook_dw For This Useful Post:
RPOLS3 (03-30-2023)
  #12
Old 03-30-2023, 08:31 PM
427.060 427.060 is offline
or
Was that for single piston or 4 piston calipers?
Edit to add: I just talked to Muskegon. They quoted me $179.95. If they send them to Lonestar, I wonder why Lonestar quoted me $219.95. I guess I'll be sending them to Muskegon.
1968 Beaumont SD396
Old 03-30-2023, 08:34 PM
cook_dw's Avatar
4 piston.
Old 03-30-2023, 08:56 PM
I used Lonestar for my 70 LT-1 Corvette brakes. No issues.
Old 03-30-2023, 09:05 PM
scuncio's Avatar
scuncio scuncio is offline
Chemistry is not my strong suit, I have been told by Muskegon that the old formula DOT 5 has not been available for several years and that current DOT 5 is not compatible with the brake parts in our old cars.
Lonestar, and I believe White Post and Karps warranty is voided with DOT 5.
If this is incorrect, please set me straight! - Bill W
That’s interesting, I’ll look into it. As long as you’re starting with a dry system, I’ve never had an issue with DOT5, other than bleeding it every 5 years or so on a preventative basis.
Old 03-30-2023, 10:04 PM
X66 714's Avatar
X66 714 X66 714 is offline
Mike Gibbons say dot 4 when he does brake parts.....Joe
Old 03-30-2023, 10:16 PM
The only advantage to Dot5 is it won't eat paint if you spill.
Old 03-31-2023, 01:32 AM
juliosz's Avatar
juliosz juliosz is offline
My 67 had DOT 5 in it since the early 1980s. The restoration was started in the late 70s and the original owner told me Dow Chemical gave him a couple gallons of DOT 5 to try. Amazingly, when I disassembled the calipers, wheel cylinders and master, all were spotlessly clean and attracted no rust, bores were all perfect as well. I have heard that this is another benefit of DOT 5.
The Following 2 Users Say Thank You to juliosz For This Useful Post:
69M22Z (03-31-2023), scuncio (03-31-2023)
  #19
Old 03-31-2023, 03:45 AM
I like Mike Gibbons. A great guy and easy to deal with. Had several parts done by him.
The Following User Says Thank You to Salvatore For This Useful Post:
X66 714 (03-31-2023)
  #20
Old 03-31-2023, 04:03 AM
scuncio's Avatar
Absolutely true - DOT5 will not absorb water, so as long as you keep it sealed to prevent ingesting moisture, it should do a good job of preserving your hardware.
The Following 2 Users Say Thank You to scuncio For This Useful Post:
69M22Z (03-31-2023), juliosz (03-31-2023)
