Old 01-25-2023, 01:24 PM
Worth the time to read the other thread mentioned above: https://www.yenko.net/forum/showthread.php?t=174044
It sounds from all of this like axles for installation in Chevrolets were painted black through 72, but at least some (if not all) Pontiac axles were not painted.
Jeff Helms
65 Z16 Survivor
65 Z16 drag car
66 Chevelle L78 unrestored
67 Chevelle L78 unrestored
67 Camaro SS350 Survivor
Old 01-25-2023, 01:28 PM
Originally Posted by ronzz572 View Post
Hopefully this helps. This is how I restored my 70 L78 camaro rear 12 bolt. Pretty much painted everything with the drums on it semi gloss black. The paint used on the rear axles wasn't very good and didn't hold up well.
Don't want to get too off-topic here, but are the sway bar bracket caps silver or is it just the flash?
Now, back to your regularly scheduled thread......
Owned since 1978 - First Car
The Following User Says Thank You to BCreekDave For This Useful Post:
Tracker1 (01-27-2023)
  #13
Old 01-25-2023, 03:09 PM
ronzz572 ronzz572 is offline
The sway bar drop rods and caps were NOS and came with no paint natural steel. The sway bar mount caps at each end are the originals and are painted semi gloss black. When I removed them there was black paint inside the caps. So based on that I painted them semi gloss black. Also after a evaporust treatment evidence of black was on the exterior. The rear end appeared to never been out of the car when I removed it. So I went with the finishes I saw.
1970 L78 camaro Cortez silver ralley sport under restoration
1970 L78 camaro cranberry red standard black interior original drivetrain.
The Following User Says Thank You to ronzz572 For This Useful Post:
  #14
Old 01-26-2023, 02:12 PM
RamAirBirds's Avatar
RamAirBirds RamAirBirds is offline
I think we are determining here that what happened with Chevrolet did NOT necessarily happen with Pontiac. In this case in seems that the 12 bolt installed in the PONTIAC F Body did not get the black paint as researched through several original cars now including one that I own. In the case of Chevrolet who DID get the axles delivered to assembly painted black YES the entire assy was painted after being built including the axle cover and bolts. The axle backing plates however seem to have been painted just around the tube leaving much of the backing plate natural metal. If you look at the other thread I started before this one
"69 F Body Rear Axle Color *Latest Consensus*"
you will see the discussion of the Chevrolet axles a little more in depth.
Old 01-26-2023, 09:15 PM
L16pilot L16pilot is offline
I'm on the "Chevy side" of this discussion but my understanding was that the 1970 F-body 12-bolt was the same regardless whether it was installed in a Firebird or Camaro and even carried the same codes. If this is the case, would it make sense to have a different paint process and how would the production plant differentiate Chevy vs. Pontiac?...I know, I'm trying to instill logic in a mass production environment from 52 years ago... My theory, (unsubstantiated, but plausible), is the paint used on the rear axle assembly was the same as used on master cylinders and brake calipers...and it "evaporated" early in the vehicle's life...but again, that is just a theory.
Steve Nuwer
www.2ndGenZ.com
Old 01-27-2023, 02:10 PM
Tracker1's Avatar
Tracker1 Tracker1 is offline
Originally Posted by L16pilot View Post
All indications are that the '70 F-body 12-bolts were painted as a completed assembly.
Not Trans Ams.
I ain't nobody, dork.
Old 01-27-2023, 02:14 PM
Tracker1's Avatar
Great Pic Tracker1. This is pretty much what i have seen on my survivor 70 TA. Very Very Light surface (almost impossible to describe as) Rust. You ca brush it off. Easy to see it was Bare Metal as well.
Thanks for posting....Look at all that over spray.
yeah this one was crazy with overspray - the line painter must have been a new hire from a Mopar plant
Old 01-27-2023, 03:47 PM
Formula455SD Formula455SD is offline
Mine is the color of dirt...
'66 Corvette 427/390 orig paint
'70 Chevelle SS454 4spd orig paint
'72 Trans Am #'s 4 speed orig paint
'73 Formula 455 SD orig paint
'67 GTO 4 speed 35k miles orig paint
'67 Grand Prix 4spd orig paint
'66 2+2 convertible 421 8 lugs
'21 Challenger Scat Pack WB
'64 Malibu SS convertible
Old 11-15-2024, 09:34 PM
RestoRacing LLC RestoRacing LLC is offline
Would this be accurate for both Norwood and Van Nuys Trans Am's?
