I work on equipment that had a large pressure vessel certified to 600psi which we operated to 310 PSI. When we decided to have some upgrades done the UK vendor refused to work on it because it had not been recertified within their guidelines. |
| The Following User Says Thank You to Rfish For This Useful Post: | ||
MarcDant (12-27-2021) | ||
We've always put a length of air line on the bottom of the tank and then the valve at the end of the air line. It allows water to collect in a rubber hose and not corrode the tank.
| The Following 3 Users Say Thank You to prototype For This Useful Post: | ||
https://eatoncompressor.com/product/...ic-tank-drain/
WOT |
Thanks Paul , I give credit to the guy that made the video and can only speak for myself and not the 800 views. I feel safer now with that home made copper coil air dryer, less moisture less water to keep draining from the pipe on bottom of compressor. As they say a little goes a long way.
compressed air can do serious damage. I had a fedEx driver needed air in his tire. I was happy to put some air in his tire. I was putting air in and the side wall blew out at 85lbs. right where i was. A 9" gash in the side , It blew me across my lot and sent me to the hospital with internal (liver) injuries. It blew all the buttons off my shirt. Lucky to be alive
| The Following User Says Thank You to plumL78 For This Useful Post: | ||
MarcDant (12-30-2021) | ||
When a medium truck tire ruptures (zippers) and assuming it has 100 PSI in it, there is 12 tons of pressure looking to get out. That is the equivalent of being hit by a tractor. Never stand in front of a tire when you are inflating it, always stand parallel to the tire. If a tire is going to explode, it almost always ruptures through the weakest, thinnest point......the sidewall. Just be careful. |
| The Following 5 Users Say Thank You to CamaroNOS For This Useful Post: | ||
69M22Z (12-30-2021), 72-SS-L48 (01-02-2022), firstgenaddict (01-06-2022), L_e_e (12-30-2021), MarcDant (12-30-2021) | ||
The way I understand how to properly pressure test a vessel is they use liquid, that way there is not much compressive pressure 0f course they over factor the tank by what ever metric they use.
As an aside has anyone seen an excavator or truck tire rupture in one of those steel cages?
~JAG~ NCRS#65120 68 GTO HO 4 spd Alpine Blue /Parchment 2 owner car #21783 71 Corvette LT1 45k miles Orig paint - Brandshatch Green - National Top Flight - last known 71 LT1 built. 71 Corvette LT1 42k miles Original paint - Black - black leather - only black LT1 known to exist. NUMEROUS Lemans blue Camaros, Monza Red and Daytona Yellow Corvettes & a Chevelle or two... Survivors, restored cars, & other photos https://picasaweb.google.com/lh/myphotos |
Something my Dad taught me a long time ago was to always drain an air compressor when you finish using it. It keeps the tank from rusting on the inside and is a general safety precaution. I don't want a pressurized vessel in my shop when I'm not there for sure!
Andy 1967 Camaro 406 4 speed 1969 C/10 383 5 speed 1969 D300 318 4 speed 1969 Super Bee 383 4 speed 1972 K/5 350 Turbo 350 1972 Duster 340 727 1974 'Cuda 340 4 speed |
| The Following User Says Thank You to Andy For This Useful Post: | ||
Crush (02-04-2022) | ||
Wow! Yeah, I’ve got a checklist I run nightly before I close the shop up:
1. Inside air line ball valve: OFF 2. Inside water separator: Drain, relief pressure in lines 3. Outside: Tank drain valve open - drain until empty 4. Outside Compressor: OFF In the morning, it’s the same thing: 1. Outside: Tank drain valve open - check for moisture overnight 2. Outside: Check tank pressure, turn on compressor 3. Inside: Slowly open air line ball valve and monitor line pressure 4. Inside water separator: Drain, check for moisture. I call it my “IN and OUT” check. Sort of like the burger place, but not as greasy! If there’s a rupture in the line or anything, I can catch it right away. Blowing the line and tank out each night gets the main moisture out, then in the AM, gets the remaining moisture out due to cooling condensation. Been very fortunate in the DFW area it’s nowhere near as humid as Houston was, and my tank doesn’t get a whole lot of moisture in it. We’ll see how that goes on the first large paint job I do. That’s the real test. Blasting and using air tools hasn’t really yielded any large moisture issues so far.So crazy, and scary, to see things like this happen. Cheers Dave Last edited by A12pilot; 02-05-2022 at 11:35 AM. |
