Old 06-12-2021, 02:23 PM
Rumbleguts396 Rumbleguts396 is offline
Default 396 Camaro Points Issues
Hi Guys,
I'm having an issue with the points in my 1969 Camaro 396. Full disclosure the motor is not stock. It's a Day 2 street car. Unfortunately i don't know all the internal spec's of the motor ( bought the motor used/built). I've had the motor running in my car for 12 years and never had any issues. It's a 1969 Solid Lifter motor with a stock single point distributer. It does have a slight cam. The motor has always been bulletproof, and super reliable.
So my issues started last summer. Dropping a cylinder and then 2 cylinders. This has happened at least 3 times and last night happened again.
First time it happened I inspected the points and distributer cap. Points looked perfect but i noticed the underside of the distributer cap had 3 or 4 contacts chewed up. Bad bushings in the distributer i figured. My buddy happened to have a rebuilt stock one near by. I installed it along with stock GM points/condensor/cap. Car ran great for appox 300 miles. Then the same exact issues popped up again.
Next I replaced points/condensor from Accel. Along with a new coil. Also complete tune up wires spark plugs etc. Same thing ran great for a few hundred miles and same issues came up of dropping cylinders.
Next I installed another set of points/condensor and left the tach wire off the coil to see if it made any difference. It ran great for 3 hundred miles and bang same issues.
I should note, whenever I changed the points they looked brand new, zero physical issues spotted. I tried different spring tension points and still no difference. Of course I set up the points, timing, dwell each time i replaced them.
I am at a loss. Has anyone had this issue?? any suggestions? should i ditch the points and install an MSD or Mallory ??? I must admit I have always kept points in my cars for the last 40 years. I always liked them.
Again, this is not a 100 point restoration. It's a Hot Rod Day 2 car.
Many Thanks, ROB
1969 Camaro SS 396 X66 Lemans Blue
1969 Corvette 427/390 Lemans Blue
