Old 04-19-2021, 12:56 AM
Rear springs are not original.
Kurt says the invoice is fake. The stampings look fake.
Is the POP fake?
Old 04-20-2021, 04:41 PM
RSSSfan RSSSfan is offline
Is the POP fake?
We all know that fake POP's have been available for some time. The seller is being a little shady about his answers to questions - "let the car speak for itself". In other words, caveat emptor.
The guy selling it may not have been aware of the monkey business before he bought the car himself. He may have been taken and is trying to cut his losses. But he should not be advertising it as a real L78 car either. Best to come clean on something like this. And the people who perpetuate these fakes burn me up. It dilutes the values of the true original cars.
Old 04-21-2021, 05:54 PM
Car has been sitting on $50k, and with an hour left, I don't see it budging off of that. There have been several people raising issues with the provenance of the car being a born-with L78. Tach, brake system, and other issues.
I can't really get a good enough look at the engine stamp to determine very much. Does the location of the stamp play a factor? This stamp is in the extreme upper left corner of the pad. It looks to me like the well plug on the cylinder head would interfere with the gang stamp if the stamps are in fact placed on a fully assembled engine, as I think they are. Can anyone comment as to when / where the assembly stamps are done? I thought that they had moved the VIN stamp down near the oil filter area, since the pad is obstructed by the alternator when they moved it to the passenger side after 68. Yet this one is stamped with the VIN on the pad. It is a December car - did the VIN location change after this date?
Old 04-21-2021, 06:50 PM
bbbentley's Avatar
You called that one
FULL OWNER HISTORY
Old 04-21-2021, 07:17 PM
Jonesy's Avatar
Jonesy Jonesy is offline
Sold for $50K. I have seen BBC engine stampings in this location.
Such poor pictures. The trans stamping doesnt look good to me.
Better pics could have helped or hindered this auction.
Reproduced invoice makes the whole thing suspect.
Old 04-21-2021, 07:40 PM
Any way to determine if the protecto-plate is legit?
Old 04-21-2021, 10:36 PM
Billohio Billohio is offline
I was thinking big blocks were stamped with the heads off??
Small blocks were assembled
Bill
Old 04-22-2021, 07:37 PM
This picture of the engine assembly line shows stacks of big block engines, all with the heads and intake/exhaust manifolds installed. That is the time that the VIN is stamped, although you are probably referring to the engine build date/code. Does anyone have documentation or pictures of the actual engine assembly process?
http://www.camaros.org/assemblyprocess.shtml#engine
Old 04-27-2021, 03:49 AM
firstgenaddict's Avatar
Big blocks are deck stamped prior to the heads going on and the plug on the front of the head will not allow a correctly placed stamp.
~JAG~
NCRS#65120
NUMEROUS Lemans blue Camaros,
& a Chevelle or two...
Old 09-13-2023, 01:49 AM
Jonesy's Avatar
Its back!!!!
https://bringatrailer.com/listing/19...et-camaro-276/
The Following User Says Thank You to Jonesy For This Useful Post:
markinnaples (09-19-2023)
