Old 06-03-2021, 03:41 PM
Does Fred use brand new upper castings and re-stamp the numbers? I never see any remnants of bolts being used previously.
Owned since 1978 - First Car
Old 06-03-2021, 04:24 PM
R68GTO R68GTO is offline
Fred re-uses what you supply. Not following the remnants of bolts reference?
The Following User Says Thank You to R68GTO For This Useful Post:
X66 714 (06-03-2021)
Old 06-03-2021, 04:55 PM
cook_dw's Avatar
cook_dw cook_dw is offline
You can see on the bolt hole closed to the outboard side of the motor that it’s been installed previously.
The Following User Says Thank You to cook_dw For This Useful Post:
R68GTO (06-04-2021)
Old 06-03-2021, 07:10 PM
I see it now. Had to blow it up a bit. Most holes are usually more chewed up than that.
