Old 10-30-2020, 04:01 PM
https://spudsgarage.com/archives/69C...roJB/index.htm
Old 10-30-2020, 04:02 PM
http://classiccardb.com/chevrolet/11...ez-silver.html
Old 10-30-2020, 04:03 PM
http://topclassiccarsforsale.com/che...-restored.html
Old 10-30-2020, 05:29 PM
Jonesy's Avatar
Jonesy Jonesy is offline
Well it doesnt look like it has any drivetrain thats original to the car.
I guess I would verify that. If thats true its not worth what hes asking, IMO.
Block Suffix: NA Decked, Stamp: NA Decked Cast: 3970010 Date: Not Accessible During Inspection
Cylinder Heads: Double Hump Heads (#'s not checked)
Intake Manifold: 3932472 = GM Aluminum 4bbl (Z-28, F Hi Rise)
Carburetor: 3932876 DZ LIST 4053 (Z-28 application)
Transmission: Cast 3925661 Muncie 4 Speed (Late Production-Non Match Vin)
Rear Differential: Stamp BV 1227G1 "E" (4.10 Ratio -12-Bolt Eaton Posi-Trac)
Old 10-30-2020, 05:30 PM
Jonesy's Avatar
124379n689590
Old 10-30-2020, 06:11 PM
cruiserofland's Avatar
cruiserofland cruiserofland is offline
RS Z grills are black unless it's a black paint car. Looks like ZL2 hood was added since the cowl flap isn't wired up. Fender droop and panel gaps esp on driver side are kinda rough, but all in all looks like a nice driver. I don't know enough to weigh in on the trim tag. Looks like a repaint based on how far down the stripes go on the cowl.
~Matt
'69 Z/28 RS
'77 F100
'83 FJ60
'10 WC50
‘24 J250
Old 10-30-2020, 06:38 PM
I think the trim tag is good, just a bit beat up. Better pic would make it easier to confirm.
Car has a lot going for it, but as stated, not likely an RS to start with, and definitely not the original trans or rear. Some guys don't care about all that. Most do.
At least they are up front about the block being decked. It is STILL POSSIBLE to verify it as being the original block, but ONLY IF the partial vin down by the oil filter is readable. Big if.
Wrong exhaust manifolds. Given the rest of the history, I would be shocked if it had the original distributor, starter and alt.
Old 10-30-2020, 11:53 PM
ZLP955's Avatar
ZLP955 ZLP955 is offline
Hmm. Not so fast. Maybe you’re referring to some of the other ad links posted by Dan later in this thread, but in the current eBay listing (the posted link that began this thread) the seller’s description states:
1969 Chevrolet Camaro Z28 X33D80
Very nice high quality -Accurate Vehicle
* 302 Matching #s
* 410 Posi Matching #s
* Muncie M21 Close ration transmission - non matching
Says nothing about being decked, and implies only the trans is non-OE to the car.
Tim in NSW, Australia
Old 10-31-2020, 12:02 AM
ZLP955's Avatar
Also, 2 of those ads that do mention the block being decked list the car’s location as Fresno CA, but per eBay, it is currently offered for sale in Wisconsin.
So if it was bought in Fresno and now being flipped in Wisconsin, the seller is presumably aware of the decked block, yet lists it as ‘matching numbers’. Tread carefully and ask questions if serious about the car.
Old 10-31-2020, 03:17 AM
You are correct Tim. What I SHOULD have said was: "at least a previous seller was up front about the block being decked."
If the current seller restamped it, ... well, that's a serious problem.
At least we have enough to go on to know the trans and rear are not original. Are they NOW claiming the 4.10 rear is matching? 12 27 rear doesn't work in a late 69 built car.
