#11
I bought some at Lowe’s in Calgary, it is window foam sealing tape, comes in rolls, & different thicknesses.
| The Following User Says Thank You to rszmjt For This Useful Post: | ||
X66 714 (09-22-2020) | ||
#12
I went to Lowe's & their selection was very thin. Same with Home Depot & Ace. Thanks, Joe
1968 Z/28 Corvette Bronze. Black Hounds Tooth. 02E Los Angeles born 3/13/1968 pnt OO 1969 SS396 Yellow/Yellow 08E Norwood born 8/28/1969 pnt 76E 1970 'cuda Moulin Rouge, 440-6, 4 speed |
#13
Maybe check with a local window manufacturer? Or can you get on line and see what local other Lowes carrys it?
#14
Good stuff: Better than Window Home use item.
Grainger (Vendor) 3M Urethane Foam Double Sided Foam Tape, Acrylic Adhesive, 1/16 in Thick, 2 in X 5 yd, Black Item # 15C177 Mfr. Model # 4056 UNSPSC # 31201527 Catalog Page # 1392 3M™ 4056 double-coated urethane foam tape roll is an open-cell foam designed for indoor use: mounting soap dispensers and air fresheners, signage, kickplates, and other miscellaneous mounting. Offers excellent shear strength, good temperature resistance, and vibration damping characteristics. Acrylic adhesive.
69 Los Z11 68 SS/RS 396/325 68 Los Z28
| The Following User Says Thank You to 169indy For This Useful Post: | ||
X66 714 (09-23-2020) | ||
#15
I know your trying to help. but I wouldn't use that its open-cell so it will absorb water. you want closed-cell
69 SS L78 Chevelle 70 SS 396 Chevelle |
| The Following User Says Thank You to Donnie For This Useful Post: | ||
X66 714 (09-24-2020) | ||
#17
its in the mail Joe.
#18
Thanks Donnie. Almost ready for it...Joe
#19
EVERY 1st gen I have taken apart has had a narrow foam strip about half as wide as the weatherstrip channel and it is kind of "goooo-ey".
My research indicates the original is a polyurethane impregnated foam seal... I have seen NOS pieces for sale in the past and it looks nearly identical to the set up I have used in restorations and is shown below. I used a open cell foam and then took a paint brush and coated polyurethane sealer into it then applied. It seals well with no wind leakage. FWIW 2nd gens used a black foam the width of the trim much like shown above. PHOTO
~JAG~ NCRS#65120 68 GTO HO 4 spd Alpine Blue /Parchment 2 owner car #21783 71 Corvette LT1 45k miles Orig paint - Brandshatch Green - National Top Flight - last known 71 LT1 built. 71 Corvette LT1 42k miles Original paint - Black - black leather - only black LT1 known to exist. NUMEROUS Lemans blue Camaros, Monza Red and Daytona Yellow Corvettes & a Chevelle or two... Survivors, restored cars, & other photos https://picasaweb.google.com/lh/myphotos Last edited by firstgenaddict; 09-27-2020 at 08:06 PM. |
| The Following User Says Thank You to firstgenaddict For This Useful Post: | ||
X66 714 (09-27-2020) | ||
#20
My LA built 68 had that. My Norwood car had different. Maybe they had a couple of different suppliers...Joe
